2007 Yukon Power Lift Gate won't Open..AT ALL
Coolhandmike
Columbia, SC
Guys,
This has been discussed in this forum to much degree but some of the posts are very ambiguous about the problems they're having. Let me tell you mine.
2007 Yukon with power lift gate will not open. I've tried turning the button in the front compartment to manual but the gate will still not open. When I switch it back to automatic/remote function the gate will still not open. When I try to open it with the remote or via the press button on the lift gate I can hear a faint noise of the motor trying to engage. I've made sure the back hatch is closed. So far I've read about struts and getting a new motor. My questions:
Have you had this happen to you?
Where is the motor assembly and can it be accessed if the back lift gate won't open at all?
I've read the manual about the battery having low voltage but is that battery also accessible without opening the liftgate?
Any and all help is greatly appreciated guys.
Michael
shundal
NorCal
the motor is located behind the rear quarter panel on the driver's side. There's one screw to remove in the rear C pillar and the rest of the paneling pops off.
GM Customer Service
Michigan
Coolhandmike,
I see that your fellow forum members have answered your question but if you find you cannot not resolve this issue yourself, I am more than happy to assist. Please private message if I can be of any assistance.
Regards,
Jennifer T.
GM Customer Care
cjsoasis
