Plasti-Dipped my Woodgrain trim for $5.99!:)
metalemt
Las Vegas
Also using this as a good time to do some detailing, apparently somebody liked graham crackers in the rear passenger window switch. Amazed it still worked like a champ though
metalemt
Las Vegas
Dash, all the metal tabs holding mine in place were beastly strong, your going to have to get it some elbow grease, I recommend more so at the actual place the tabs are.
Driver side AC hole, vent comes out easily but the tab is on the plate side.
Plate and tab.
Removing duct from bezel. Same tabs top and bottom all vents.
Upper dash holes.
Tabs from upper dash, passenger side of AC vents. I laid this down so the part towards the bottom of the picture in reality is the top part that would be closer to the windhield.
Tabs from upper dash driver side of AC vents. Same angle as last.
Radio holes
Radio Bezel, it's on backwards to show location , 4 on each side and one on the bottom.
ghostworks
Norway
Awesome dude! Now I know where place my plastic tools :)
Thank you for taking the time to take pictures and post!
metalemt
Las Vegas
Only thing I would add is make sure it has dried a couple hours before handling I was impatient an did after 45 mins, it's solid but the ones I touched have a velvety fuzz and white discolor
kathrinebrown
