Service 4x4 light - which switch?
DjLarroc
gdddup
NJ
theyre all the same. just different aftermarket brands
D
DjLarroc
Ok, just ordered the $30 switch lol..
I have not really looked at how it comes out. Any tips to replacing the switch? Taking off the trim piece?
My01yuk
Dallas Tx
Yes, take the dash trim piece off, it will help to put the gear shift in neutral so you can bettet pull the trim off. Use your fingers to seperate the trim from the dash....snaps off and back on. You will be able to see the switch unit better then. You will need a small flat head screw driver to pry the tabs on the side so that you can pull the old switch out. You will have wires on the back that will limit how far you can pull the switch out, simply unplug the wires. Then plug the wires into the new switch and snap back in the place.
D
DjLarroc
Got the part from Rock Auto the following day.
Installed in 10 mins. 4x4 is working great.
Thanks guys! :Handshake:
gdddup
NJ
sorry to thread just but the service 4wd light just came on yesterday while i was driving down the highway in 2hi. everything seemed fine. when i got home i shut off thed truck n restarted it. and no more light...idk but it hasnt been on since
My01yuk
Dallas Tx
gdddup,
Sounds like you have the same problem bro. If everything seems fine then i would start with the 4WD selector switch. Cheap part and easy to install.
Vettexan
