Rear Seat Fold Down Problem...HELP!
Rudder
Ok guys, I am currently looking to install a seb box underneath the rear seats of my 1999 4DR Hoe, and as I was lifting the seats up to take a look underneath, the driver's side rear seat (the bigger one) would not release. I could pull the latch, but it would not release and I could not pull the bottom portion of the seat up and forward.
I am guessing that the cable is broken...?
Anyone have any ideas on the easiest way to fix it?
Should I do it myself or just take it in to a dealer/shop to deal with it?
Thanks for the input,
Cheers
fyremanpat
Fyremanpat
can you see that the cable is broken? If so is there enough hanging out to grab with pliers...or you could always just unbolt it and pull it out and go from there
R
Rudder
I can't see that its broken, I am just guessing it is since the seat won't release.
Would there be another reason that it wouldn't release?
fyremanpat
Fyremanpat
does it feel like there is tension on the release? maybe pull a little harder..the release leaver that is..haha..mine sticks so I have to put a little umph into it
blackcoffee
O.G. Black.
Tear those damn seats out, tell the bitches to ride on the roof rack.
drowndindreams
Unknown
do you feel any weight on the cable? if anything you can just unbolt the seats during the install
branndon_b
Lake Charles, LA
yeah, my cable is broken too. gotta figure a fix. i'll work it out though, low on the priority list.
---------- Post added at 10:29 PM ---------- Previous post was at 10:14 PM ----------
if the cable's frayed, it may be catching on the foam. like was mentioned earler, just pull harder. may free up for ya
R
Rudder
Yeah, it still feels like there is tension on the cable, but I reefed on 'er pretty hard, and nothing moved.
I guess I will take my wheaties in the morning and really give it a good pull....hopefully she comes free for me.
Thanks guys
TheBeast99
lol i accidentally ripped out the cable last weekend trying to get mine to fold down
it just kept coming out until *doink* it just snapped
i think i'll try replacing it with something a bit stronger... like a short length of chain - then there's no way it'll ever snap again!
R
Rudder
Tried pulling as hard as I could and nothing....didn't even get it to break (which probably would have been more satisfying then having nothing happen at all)
Still have no idea what I should do....starting to get rather annoying I must say.
branndon_b
Lake Charles, LA
may have to unbolt it and pull it out, and hose down the latching parts with some wd-40 or something, maybe it's frozen up at the latch. just be less mess out of the truck. think there's 7 bolts to take out -- one on each side in the front, one on the hump at the front, 2 in the middle at the back, and one at each end in the back. may be your only option to see what's going on. branndon
TheBeast99
well at least we're not messing with any complicated electronics here - it's just a seat :) that's a plus
ewheelin
Just wondering how you made out with this. I just tried to flip up my rear seat (also a 4dr) and the strap pulled right out. It broke the cable, and with out to much effort. Not sure what will have to be replaced, but I hope they sell the cable and the pull with out having to replace the whole mechanism.:emotions122:
Shel
TheBeast99
i tried the other day to release mine using a pair of steel locking surgical needle holders from work. was grabbing the last bits of steel threads, but wasn't enough grip.
then my co-worker tried working it from underneith,and i didn't know that cloth under the seat was just velcrod on there, ya.... i'm gonna be cleaning that shit from the stuff that fell thru the seat from the previous owner.
first thing i said was "i've never had a lolipop in this truck...... ewww"
retorq
Kingman AZ
My release broke along time ago. I was able to get the seat to release and I immediately went and got my cut off wheel and cut the locking bar on the bracket. I can pull the seats up when ever I want now without any hassle.
toy_spd
So. Cal
i just had the same problem, i took the side hing off and it was locked in place it would not budge, once i took it off i popped the spring off and rotated the locking plate. then i just ground down the tip of it, then finished it smooth with a wire wheel, put it back on and left the wire out, since it was already cut, i could not put it back to stock, so i left it out.
now i just pull on the wire and it folds down.
Ron Oh
Cheers
I've had the same problem and resolved it today. The 60% seat bottom on the passenger side has a fabric pull that rotates a shaft which has 2 locking pawls on it at each side of the seat. The pawls lock on to a loose shaft (anchored to the floor) that is centered with a mechanical guide which is right beside the pawl. You can release the seat by getting your hand up there and helping the mechanics rotate while tugging on the fabric pull. To get there. Remove the plastic side cover under the bottom seat edge. Reach under the seat at the driver side back door, at the back edge of the seat bottom, the edge nearest the back window. Feel for the mechanical pawl and help it rotate while pulling the fabric pull. I'll load pictures in a sec.
JamesinAbilene
