Tahoe 2010 with CAI & Magnaflow Help !!!
jee123
that sucks man hope you get it fixed...maybe take it off and reinstall it. sometimes it helps
dmerk1978
Long Beach
i have a better question, i'm unaware of the 2010 magnaflow even being released, are u running a 2009 exhaust on a 2010 truck?
madrule2002
MSRP:
$765.23
PART #:
16564
YEAR:
2009
DESCRIPTION:
V8 4.8L
5 x 11 x 22 in. Muffler, 3 in. Tubing; 3.5 in. x 5.5 in. Oval Tip, SINGLE REAR SIDE EXIT
SOUND_CLIP:
No Media Clips Available
DYNO RESULTS:
No Dyno Sheets Available
INSTALLATION:
Install Sheet not available
CHECK INVENTORY:
Check Availability
bro check the info its written 2009 , i am not an expert but maybe 2010 MF for ur car not released yet
dmerk1978
Long Beach
i'm not sure either, all i know is that a 2009 should not fit a 2010, unless custom fitted by the installer, i'm unware of any exhaust being to market on 2010 unless custom made or r&d from the manufacturers. just my 2 cents
Zed 71
Pacific NW
IMO the 2009 should fit 2010. I am not aware of any changes that would affect exhaust fittment. However, the CAI for 2009+ are definitely not compatible with previous years because the MAF housing is different.
My previous post was regarding mad's where he indicated the exhaust was not compatible because of the MAF. There is no direct correlation between the exhaust and MAF fitment wise.
Volant1
Volant guy
Upland, CA
If the battery cable is not unplugged or the o-ring is not swapped out your kit will through a check light did you get the problem fixed?
beka1283
