another lowering question...
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob i have a 2/3 kit for $300 if your interested.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
on the autoride trucks you will get about 4.75 inches you will need to modify the links shorter.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Hi the! Hows the lowering doing? What kit did you got?
Actually, if you haven't lowered your truck yet, I would suggest the Belltech Stage 3 lowering kits for trucks. It already includes lowering components needed to get your truck sitting low and pretty, and it also includes a set of Belltech's street performance shocks.
my custom djm 3/5.5 kit sits lower and rides better. the belltech kit for 3/5 you use keys in front with spindles which ride isnt as good as the djms and rear at the 5 inch drop you need the trailing arm links/swaybar relocators which djm makes.
I sell both kits belltech and djm and for the 00-06 tahoes the djm 3/5.5 kit ive sold on here rides better.
Preludepearl417
NORCAL what do you guys mean by messing with the torsion keys?
I have a 2/3 kit from Ground Force (springs,keys,shocks). What do i need to do to make it lower?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
how much lower do you want to go? in both front/rear?
Preludepearl417
3/4 is what i want. I figured i can cut the rear springs and then do the whole turning the keys thing in the front. Is that possible? What do u do with the keys in the front?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Preludepearl417
wont align in front by turning keys.
rear you cant cut that much from the spring to get that drop ride horrible and springs will pop out.
Honestly the djm 3/5.5 custom drop kit I sell will ride great lower it the right way and comes with all brand new shocks all around
Here you go.
http://www.tbssowners.com/store/index.php?act=viewProd&productId=88
or my djm 2/3 kit with shock extenders
http://www.tbssowners.com/store/index.php?act=viewProd&productId=90
Thanx for the info. Ill stick with my 2/3 kit. Wifes gonna have my nutts if i spend anymore money on the Sub......
kahnor
