Getting the Ride Back
Tahoewhat
Ballin' on a Budget
TX
So how much drop are the new beltech TBSS suppose to give w/o cutting. No helper bags. Im on the 5305's and wouldnt mind going lower and ride is fine on mine now.
M
Max
Mile High
Denver
I'll know tomorrow but the current tb coils are about an inch lower than my 5305s after they settled.
bub
jersey
your belltech tb springs vs. my djm tb springs. i'll grab some measurements.
M
Max
Mile High
Denver
Cute little baby helper bags ftw! I may come in early and get everything dialed up tomorrow morning but it depends on how busy we get.
M
Max
Mile High
Denver
Installed everything and roto/rebal'd the tires and damn this thing rides nice with 5psi in the bags. I'm the same height and the ride is back, I'm going to get it washed and then I'll try to throw some pics up but the drive home was the smoothest it has been since my 5305 coils with helper bags.
M
Max
Mile High
Denver
I've been driving around places that my truck struggled with before and it rides so much better with the new setup, the truck exhibits far less sway with the helper bags installed and feels solid on the highway at higher speeds. Was a bit dark already but I managed to get a few pics, front is at 30.5" and rear is dead on at 31" with the helper bags just north of 5psi. I hope they settle a bit so I can run more pressure in the bags but the little guys give me far less lift than the old ones did due to the smaller size.
For anyone contemplating a rear spring setup the belltech trailblazer coils + airlift helper bags are the way to go. I'm so happy this thing finally rides smooth over big ass potholes and dips, was just ripping the shit out of it and she takes corners amazingly well now, full throttle opposite lock around corners is so damn fun in this thing :evillol:
Old tb coil vs new tb coil + helper bag
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
max i knew the result would be the same as ive said :)
also cut 1 loop flatin the coil and put the untouched side on the axle. Truck will come down about 1/2 to 3/4 inch.
glad you like the ride.
---------- Post added at 08:05 PM ---------- Previous post was at 08:04 PM ----------
the djm spring is a wider spring with less coils vs the belltechs.
Tahoewhat
Ballin' on a Budget
TX
So the new designed TBSS beltech coils are alot better than the older ones. Without the bags aired up, how low would it be and do you think the ride would suffer without those? Max, how would you compare them to the 5305's? Id like the rear lower, just wondering about the diff.
Bub-- looking forward to seeing some pics or measurements of your djm springs.
jlmabiepsu
