Getting the Ride Back
bub
jersey
Tony what are the differences between my djm TB springs and the ones Max just put in?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no the kit i had on the site is the djm tb spring which ive been using for a while. With the belltech rear spring the truck will bottom out more with helper bags in both cases will not.
but due to the size/winding of the djm tb spring it handles loads a lot better.
and the new design tb spring from belltech has been out for a while and ive been using it just the rear is a lot lower and you need to drop the front at least 4 inches to match. Im the one who told max about the new design spring last week
Nickleahy23
Portage/Menomonie, WI
gotcha...
M
Max
Mile High
Denver
Too busy enjoying the ride and getting it sideways again, I'll try to get some pics tomorrow when it rains all over my nice clean truck.
bub
jersey
sounds good man. grab some fender measurements as well.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yank ptb3600 stall with 4.10s
do that it will 60 foot hard!!
M
Max
Mile High
Denver
30.5" up front and 31.5" out back with about 15psi in the bags. I can air it out and drop it to 31" at 5psi but it rides better with more pressure in the bags. I think I'm gonna run a slightly taller tire with the 22s so hopefully it doesn't rub.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
my customers with the replica 22x9s and 285 35 22 and bagged in the rear there is no rubbing issues. Just like I worked with FR on the original tbss 22x9 for 2 1/2 years i helped spec the offset for the newer trucks also when they went into production of the wheel for the 6x5.5 bolt pattern.
jlmabiepsu
