Wiring the fog lights to come on with headlights
Mr. B
Rockford, IL
I did this mod with the diode. It worked like this, no fog lights with the DRLs, fogs on automatically with low and high beams.
The diode burned out, so I replaced it with a straight piece of wire. Now it works like this, fog lights on with the DRLs, fogs on automatically with low beams, no fogs with high beams.
I don't get it. Does anybody have any idea what may be going on? I don't want the fogs on with the DRLs. I may just pull the wire and deal with how it was stock. Or, is the a more robust diode I could use?
BigRed76
SeniorGroupbuyMember
New York
what you're experiencing is the exact way it is intended to work ..... as far as I know
dheadv8q
Oviedo FL
Get yerself a relay that can be adjusted for pickup voltage. Adjust the relay to pickup when the voltage is higher than the DRL voltage.
Mr. B
Mr. B
Rockford, IL
Just had a chat with one of my EE buddies here at work. The 1N4004 diode is rated at 1 amp. He believes that is the problem. Depending on the wattage of our fog lights, the diode probably needs to be in the 3-5 amp range. Therefore, we are burning out the 1 amp diode. I see on the Radio Shack website that the offer a 6A-50V diode. I'm going to buy a pack of those and give it a try again.
He also said it is fine to run diodes in parallel, so if one is in there and gets hot, you can add another one and see if that helps. My guess is I'll be fine with the 6A diode.
007fl
Tampa Bay
If you were using the diode to control the relay it should have been fine. The relays don't draw that much. But your buddies right, you can just parallel several diodes to lower the load on each and keep them cool.
Mr. B
Mr. B
Rockford, IL
I could have swore the fogs stayed on with my high beams before. They don't now, with the diode or straight wired.
stevek
Dallas, TX
The fogs turn off with the high beams, they aren't intended to be on with them. In two 07 Tahoes, an 08 Yukon, and an 09 Denali they all do the same - I doubt it's an error.
jdub5256
J-DUB
Frederica Delaware
I think what he is trying to do is overide that so that when he turns on the high beams the fog lights stay on as well. I did this same mod its in a write up somewhere on here. but mine was fine i would turn the truck on at night and low beams come on plus the fog lights but when i would turn on high beams the fogs would stay on as well as low beams plus high beams. but at that time the diode would burn right up. took the diode out and ran a straight wire no more probs. during the day drl's are on at night low and fog lights come on when i hit high beams all lights are on it works great.
BC Lightning
Unless you add the wire, I jumped my fogs with a wire and no diode (used a diode at first and burned right up) and my fogs come on with my low and hi beams
Zed 71
Pacific NW
He is jumping the fuses to have the fogs on automatically with low/high beams.
Mr. B, check that the jumper is connected to the right fuse and also the right prong on the fuse. If your fogs are 55W then you need a 5A diode at a minimum. Keep us posted.
Warrior0977
