Complete Lighting/LED List
haks310
Got LEDs?
SoCal
Complete OBS Lighting/LED List
This pretty much covers most all the bulbs you can replace without the need of soldering or anything. List is broken down by the application, bulb type and the amount you will need.
Here are some places that sell LEDs:
http://www.v-leds.com/
http://superbrightleds.com/
http://www.oznium.com/
Exterior
Low Beam: 9006 - 2
High Bean: 9005 - 2
Fog Lights: H3 - 2
Parking Lights/Turn Signals: 1157 - 4
Corner Lights: 194 - 2
Third Brake Light: Assembly
Tail Light: 3157 SRCK - 2
Stop Light : 3157 - 2
Back up Light: 3157 - 2
License Plate: 194 - 2
Interior
Gauges: 194 - 6
Indicators(instrument panel): T1.5s - 16 total, but will vary depending on how many indicators you have operational.
HVAC Controls: T1.5 - 4
4x4 Floor Shifter: 194 - 2
Ash Tray: 194 - 1
Glove Box: 194 - 1
Headlight Switch: NEO4 - 1
Door Lights: 194 - 4
Floor Courtesy Lights: 194 - 2
Driver Switches: NEO 4 & NEO 3 - 1 Each
Front Passenger Switches: NEO 4 - 1
Rear Passenger Switches: NEO 3 - 2
Dome Lights: 211 - 2
Map Lights: 194 - 6
Modded
That Guy
Nice thread, too bad LEDs in a high, low or fog install will only be cosmetic. Because though my 9006 fog LEDs are bright, they have no light beam/pattern.
Kinda weird.....
haks310
haks310
Got LEDs?
SoCal
Kinda weird.....
Yeah, wasn't doing it as a LED list just a lighting list as a whole so I threw those in there. Hopefully in the near future they will be more than just cosmetic in those applications.
mikeykey
Hak310, when you ordered the LEDS from v-leds.com which particular ones did you get?
The two colors I'm getting are blue and white in 194. There is like 3 different type bulbs that might work.
This is my list below with the colors I want. Should I consider getting different types for the different applications.
Exterior
Corners lights (4) 194 white
License plate (2) 194 white
Interior
Gauges cluster (6) 194 blues
Ash Tray (1) 194 white
Glove Box (1) 194 white
Door Lights (1) 194 white
Floor Courtesy Lights (2) 194 white
HVAC Controls (4) T1.5 blue
Headlight Switch (1) NEO4 blue
This is what I'm talking about:
http://www.v-leds.com/Exterior-LED/...ite-LED/2-HID-WHITE-6-LED-LIGHT-p4481033.html
http://www.v-leds.com/Exterior-LED/...ite-LED/2-SUPER-HID-WHITE-4-LED-p4481083.html
http://www.v-leds.com/Exterior-LED/.../White-LED/2-HID-5K-WHITE-SMT-5-p6985865.html
haks310
haks310
Got LEDs?
SoCal
It will depend how much you are willing to spend, I kinda went with their high quality lights. The NEO wedge bulbs will you have to get from superbrightleds.com. Let me know if you need help on other applications.
Corners lights, ash tray, glove box and gauges: http://www.v-leds.com/Exterior-LED/...ite-LED/2-HID-WHITE-6-LED-LIGHT-p4481033.html
License plate and door lights: http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/V-LEDS-HID-WHITE-4-LED-p5768086-1-2.html
Floor lights:http://www.v-leds.com/Exterior-LED/...-LED/2-HID-WHITE-HIGH-POWER-p4481133-1-2.html
TahoeGoBoom
blue interior guy
haks, just outta curiousity, do your gauges have hot spots with those leds? they all point 1 direction..
CodeB4U
Houston, Tx
haks310 what lights are those on you avatar?
What about DRL numbers? I just put some LED on my DRL's it lookee nicee
haks310
haks310
Got LEDs?
SoCal
No, not really, they have a nice spread. I'm stock right now though as my brother uses my 'Hoe while he fixes his. He says he can't get used to them lol
Those are V-LEDs dual color changing bulbs, 60 LEDs, 30 white and 30 amber. I'll post the link tomorrow as, I'm on my phone right now.
mikeykey
Thanks Haks!!!! Money is not really an issue. I'm not looking to do it cheap but looking to do it right the first time!
haks310
haks310
Got LEDs?
SoCal
I would of used the same LEDs I am running in the foor lights in the corners but they were a bit too big. Also the door and license LEDs are slightly different than mine, mine only has four LEDs compared to the six these have. Could not find the four LED ones, they both have the same concept with them pointing 90 degrees.
TahoeGoBoom
blue interior guy
well we should prolly clarify that this list is for OBS hoes.
newer ones are different
haks310
haks310
Got LEDs?
SoCal
mikeykey
Your link shows the four LED bulbs. I'm scratching my head here..... Did you mean to say you got the six bulb ones and you can now only find the four bulb ones?
http://www.v-leds.com/Interior-LED/D...68086-1-2.html
roadrageror
ROADRAGEROR
alberta,canada
what kinds cost for a whole int? Does anywhere see all as a package deal? I never really gave my int lights that much thought before but it is now on MY to do list!!
MonteJ
