SLP Power-Flo™ exhaust
Sasquatch
Orange County N.Y.
Never seen that system but i have a flowmaster catback with the same dual outlet. It also came with a spacer to move the brake lines, It only moves them an inch or two and it was really easy to install.
jimweis
jimweis
Lancaster, PA
I decided to purchase the SLP system, they list for $699 I paid $349 on Ebay for one. I don't like the box or trapazoid tips so I purchased some SLP slashed 3" outlet tips for $34 on Ebay they sell for $79 list. All parts are stainless steel
Sasquatch
Orange County N.Y.
I like the same style, I got four inch slash cut stainless ones too. They`re much better looking than the rolled edge ones that came with my catback.
Post some pics and a sound clip if possible when you get it done. I`ve never heard any exhaust from slp.
lorax54
Denton, TX
I just installed a flowmaster cat back. Dual side dumps. Don't know if it is the same as yours, but I didn't have any brakeline relocate. I noticed my differential vent line was close, so I just zip tied it out of the way. Where were your brake lines too close to the exhaust? Better triple check when I get home. Thanks.
Sasquatch
Orange County N.Y.
I have part number 17419, this is what the instructions said.
Look at the rear end housing at the top; you should see a bracket bolted to it holding the
brake lines. Unbolt the brake line from the bracket then unbolt the bracket from the rear
end housing. Then take Flowmaster’s bracket #HA594 and bolt the longer end to the rear
end housing using the original bolt. Then take the 5/16” bolt, washer, lock washer and
nut and fasten brake lines to the new bracket. This should move your brake lines forward
about 1” to assure clearance from tailpipe
KrautBurner
Bremerton, Wa
report on the sound?
I've had great experience with SLP products.
the LM (Loud Mouth) exhaust sounds great on the GTO's
but the LM2's are pretty damn loud ;)
jimweis
jimweis
Lancaster, PA
It's a bit loud for my taste, straight through muffler with stainless steel packing. I ran it two weeks and hated it. This weekend I put a Car Chemistry 3" insert in the intermediate pipe before the muffler, much better now but still is loud at light take off much quieter when driving aggressively.
joshwas4here
