had to replace my fuel pump over the weekend
redemn93
Jupiter, Fl
wow. im amazed. it runs so much smoother and has a good amount more power. should make towing much better now.
tybardy
everyone needs a Hoe
Gilbert Arizona
No shit... people need write-ups and pictures, and stories, and details... Help the masses with info man
---------- Post added at 03:27 PM ---------- Previous post was at 03:27 PM ----------
also, what did it cost you in parts and tools (any special tools needed?)
R
redemn93
Jupiter, Fl
well, it isnt hard at all. literally only 2 bolts. i got the pump for free. i work for a leading aftermarket part manufacturer. i got lucky and we had one at the lab. we modeled off a delphi which is $300 in the stores.
i didnt take any pictures but its very straight up. i didnt have time. needed the truck up ASAP to be somewhere. the hardest part was paying $30 for the hold down ring, the piece that hold the module (fuel pump assembly) into the take. no parts stores around here carried it. had to drive 25 miles to a dealer.
Procedure:
1. pray that you have a very little amount of gas when it dies
2. lift the rear of the vehicle and support with jack stands on the frame. if you support the rear end you wont have room to work.
3. at the rear of the tank and above it are the fill line and vent line. disconnect them but not at the tank. you will see another place to disconnect them left than a foot away from the tank. you will need some line on the tank to help drain if necessary. they are held with good old hose clamps.
4. grab a 2x4 that is 2-3' long and a floor jack. place the 2x4 on the jack and center it length wise on the tank. place just a small amount of upward pressure on the tank to support it.
5. remove the 2 straps that hold the tank up. 1 bolt for each.
6. slowly lower the jack. at this time place something to catch any fuel that my drain from the short amount of line coming from the tank. only the rear of the tank will lower. you will see that the front of the tank will be supported by a crossmemeber. thats fine. leave it. once enough fuel has drained out, let the rear of the tank sit on the floor. keep an eye on the fuel lines as the tank lowers. you may need to disconnect them before the tank hits the floor. no special tools needed. just fingers. squeeze the clips and lines should pop off.
7. you will see the pump is held by what seems to be an complicated clamp if you have never seen one before. there will be three fingers sticking up. those are stationary on the tank. they dont move. the hold down plate rotates under those fingers and locks into place. study the fingers and the grooves they fit into for a minute and you will see which way to twist the ring. use a brass punch and a hammer. if you dont have a brass punch USE SOMETHING THAT WONT SPARK...PLEASE. you will see notches to tap the ring and make it turn. mine was rotted. the more i hit is the more it fell apart.
8. once you get it moving, do not remove all the way. vac out any debris first. you dont want it falling in the tank. now remove the ring and module by pulling straight up on the module and twist as needed to get the sending unit float out. if the ring is rotted replace it. just to be safe and easier to remove next time.
9. grab the new pump and reverse the procedure to install. its very straight foward. the most difficult thing is getting the ring off if its as bad as mine.
a few tips. take a break from time to time so you arent breathing fuel vapors the hole time. wear safety glasses. sand will fall from the straps and other places. plus fuel in the eye hurts. trust me. if you find debris on in the module or the strainer is gummed up, pull the tank completely and clean it out completely. thats what killed the pump. mine was clean thankfully. cant afford for my truck to be down for 2 days letting a gas tank dry.
disclaimer: i am not responsable if you blow yourself up. thanks.
i just did this real quick. please forgive any spelling, grammer errors. ill rewrite as needed and place in the tech section when i can.
Xav8r
Greater Sacramento
Thanks Jason ... that was perfect. I tried to do the r&r in my garage while under a time pressure and was following the Chiltons procedure, i.e. removing the brackets and lines up front et cetera, and got stuck whilst running out of time. I wish I had this write-up then. Don't sweat the spelling and grammer errors ... I'm pretty sure most will appreciate your efforts at helping us out with you knowledge and experience!
zyka1
Hay Jason ( or anyone else in the know for that matter) would that bew the same on a Yukon 2000 5.3L 4wd or not. My fuel level sensor is gone. I need to work on mine next weekend.
R
redemn93
Jupiter, Fl
yes. should be exactly the same from 2000(nbs)-2006. suburban and yukon xl would be similar i would guess. just a larger tank.
Rivieraracing
Bump for me!
---------- Post added at 09:32 PM ---------- Previous post was at 08:43 PM ----------
Does anyone know off hand how long our fuel pumps should run when you turn the key to the "on" position, one click short of starting the truck? Will it only run until it builds up pressure, or is it a set amount of seconds to prime the system? I've got some diagnosing to do tomorrow, all I know so far is that the fuel pump relay is good!
R
redemn93
Jupiter, Fl
not sure. probably just till pressure is built. could be anywhere from 5-15-20 full seconds? get yourself a fuel pressure gauge and actually accurately diagnose your problem. i bought one years ago for $30. has come in handy many times. pressure with key on will be between 45-50psi on a healthy pump. around the same at idle. i only had 18 psi or so and no leaks. fuel pump it was.
Rivieraracing
Thanks for the info and the great write up, I dropped my tank just a bit ago and got the fuel pump out!! Unhooked the plug going to the fuel pump put my dc power supply to it and sure enough dead as a door nail!! So now just waiting for my dad to see how much cheaper he can get an OEM one for, 2 different dealerships want $521.28 for one!! OUCH!!! ha ha ha!
Also took some pics while I was waiting and will post them up on here for others to see what it takes, once you know what you have to do it's pretty easy!!
R
redemn93
Jupiter, Fl
if you cant get oem. get a delphi. still a little expensive but good quality. do not use airtex. im in the industry so this is first hand knowledge of who makes the good stuff.
smurphy80
521.28 is what I paid for mine when I just had it replaced 2 weeks ago. That and about 1.5-2 hours labor for my mechanic to put it in for me. Didnt feel like dealing with replacing another fuel pump. Done it once and that was enough that $200 in labor is worth it to me when the part was that much. Also mine didnt fail prior to replacement, but I did have the occasional hard start and mechanic said he could hear the old pump bumping and popping in the tank, turned out the pickup tube had cracked (like sucking soda thru a straw with a crack).
BlacktopBandit76
