Custom 6 inch drop springs TESTED AND APPROVED!!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
$225 shipped you will also need the rear djm kit and belltech sp shocks
http://www.tbssowners.com/store/index.php?act=viewProd&productId=183
Member psysh1 came to my house today and I wanted to test the custom spring I made for production for his truck.
Currently he has on the back of his truck
DJM TB COILS
DJM HARDWARE KIT
BELLTECH STREET PERFORMANCE SHOCKS
BELLTECH SWAYBAR
He loves the ride now and was willing to help me out to get some feedback.
His truck is on 285 40 22 with the djm TB Coils truck sat at 32.25 from ground to fenderlip.
here is the djm tb 4 inch springs (left) compared to my custom springs
then i put them in and remeasured and sits at 31 1/8
So overall you will get about 1 inch of drop and at this point you will need to c notch the frame. Even with the rear end not notched ride is very good but it does bottom out when you hit a big bump but normal driving over things its not bad at all which psysh1 will chime in shortly on.
---------- Post added at 05:48 PM ---------- Previous post was at 05:27 PM ----------
btw the coils will take about 6-8 weeks for first batch to me made.
Physh1
This spring rides great...very much like the TB spring but a little lower. A notch is def. a must. We drove around a few miles & it bottoms out lightly on big dips or bumps.
If I wanted to go lower this is the answer. I was really impressed on how well it rode that low.
Cameron
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
with the djm 3 inch a arms and rear tb springs it sits about even. (1/4 inch higher) with these springs 1 inch lower than front.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you can try that also but then it will bring you up to the level of the djm 4 inch tb springs. You have like maybe .75 to 1 inch of travel before axle slaps the frame with these springs in.
thehoe92
fo sho
The916
you should start selling bolt on c-notches since the obs has them but nbs doesn't :D
I would buy in a heart beat
Stevemo70
