new headlights!
btp001
Lagrange GA
blacked out headlights, bumper lights and corner lenses, 35w 8000k lows and 55w 8000k highs...need to be adjusted down ALOT when i feel like takin the whole grille off again and wiring up the quadbeams.
What
BEFORE:
AFTER:
96ProCompTahoe
IN
hows the light output? do they have blacked out reflectors in the light or is it just the outer lense?
they look really good!!
btp001
btp001
Lagrange GA
just the lenses are tinted and its the normal silver reflectors in the inside..i have to adjust them down a good bit to get the maximum output so the only thing i can tell you is theyre bright as hell ha
99Yuk
Northern Ontario, Canada
Damm! These are the first set of pics of a fella buying smoked and posting them up!
I came thiiiis close to buying smoked myself. I was talked out of it HERE. When the lights are turned off and the truck is just sitting there, smoked looks so good.
Look at this comparison of the Jeep and Tahoe. The turn signals and headlight beam look to be good when looking at them straight on, but look at what happens at an angle, you can barely see them. Wow.
How do you find the light output compared to stockers?
BigDaddy13440
Rome, NY
That's Exactly what I want to do, but I want to use the 55w 8K's in my low beams. I hope the additional output would be comparable to using 35W 6K's in clear housings.
the big blue bus
richmond, va
i have to say those look real sick on your truck. the black lights match the grill part i like it a lot. do u have black corners too? i cant tell
btp001
btp001
Lagrange GA
yea but for some reason the lenses arent tinted but the backgrounds are black..i didnt even notice when i was buying them but its not too bad
memakos
