Wheel offset question?
dan291000
Jacksonville,FL
I have 99' 2 dr with a 3" BL and 33's.(the wheels that are on it now came with the truck so I have no idea what the offset is) What would be a good offset wheel to compliment my setup without clearance issues? I will still be running 33's. I don't mind if the tires stick out past the flares a little, but not to much..Appreciate the help. I am looking at these.
http://www.rimzoneonline.com/category/0073/Moto-Metal-957-Matte-Black/
I like these a little more... http://www.rimzoneonline.com/category/1062/Fuel-Octane-Black/
BigDaddy13440
Rome, NY
http://www.tahoeyukonforum.com/forum/showthread.php?t=21525
If I'm not mistaken, I think the stock backspacing is about 5"???
If you're planning on the 17x 8.5's, Zero offset would be 4.25" backspacing.
The -05mm would space the wheel out more, and would likely create clearance issues with the fenders and bumpers. The +14mm offset would be the closest to your stock backspacing.
992door
Greenville, NC
I am running 17x9 with 4.5BS and -12mm offset and they are about even with the flares.
this is with 285/70/17
dan291000
dan291000
Jacksonville,FL
BigDaddy13440
Rome, NY
If he's got a 12mm offset, and you've got a 14mm..... your rims will be tucked less than 1/8" more than his. Looks like the lugs on your sidewalls are a bit bigger than his though..
BigDaddy13440
Rome, NY
Mine are -12 the ones he is looking at are +14 so that is about 1" difference
According to this, his will be tucked in. Positive offset pushes the wheels in further
Of course, that's assuming the wheel website lists the offset correctly.
Edit: just checked my wheels online, I bought the +25mm offset version of my MB Blitz's, they push the wheel out further than the -06mm version does. So you're correct, they would stick out about an inch further.
Most likely, he'll need to do some fender trimming and cranking.
BigDaddy13440
Rome, NY
992door
Greenville, NC
Read ^ again in one part you said his will tuck more and the next you said they will stick out farther.
BUT you are right a positive offset will tuck more than a negative. SO if he gets the one with +14 his will be about an inch more in than mine are.
The wheels you have on there now look like they might be 10 wide maybe. So you should be fine with whatever you choose from the ones you have posted
Skylander
