L.E.D. Bulb Conversion/Cross Reference List
NathanJax
Vacation Nathan
Jax, Fl
Here's a list for all the 2000-2006 S.U.V.'s that are wanting to do the LED conversion to your interior and puddle lights. My info is coming from www.SuperBrightLEDs.com . I am in no way affiliated with them, but I've been ordering bulbs from them for 5+ years with no problems what so ever. Fast shipping, 1 year warranty, etc.
Doors - 2 - Get the 194 WLED-x-x LED bulbs 120 degree angle. Getting brighter ones doesn't do any good.
Colors:
Red
Amber
White
Blue
Green
UV Blacklight
Map Lights - 2 - Get the WLED-x6 LED bulbs. Because the plastic shield goes around them, there is no difference if you get the high powered ones, so don't waste your money.
Colors:
Red
Amber
Cool White (Blueish White)
Natural White (Regular White)
Warm White (Yellowish White)
Blue
Green
UV Blacklight
Puddle Lights - 2 - These go under your outside side mirrors. Get the festoon 42mm 4210-xHP6 high powered bulbs. They are a little trouble getting them in and then aimed correctly, but they make a world of difference.
Colors:
Cool White Cool White (Blueish White)
License Plate Lights - 2 - Get the same 194 WLED-x-x LED 120 degree angle bulbs as the doors. Getting brighter ones doesn't do any good.
Colors:
Red
Amber
White
Blue
Green
UV Blacklight
2nd and 3rd rows...
Dome Lights - 2 - (the middle bulbs that turn on with the doors) Get the same festoon 42mm 4210-xHP6 High powered bulbs as the puddles
Colors:
Dome Switched Lights - 4 - For the left and right side bulbs that come on with the button, you can just get the festoon 4410-x9 LED bulb, because you hardly ever use them and they are $12 cheaper per bulb then the high powered...
Colors:
Red
Amber
Blue
Green
UV Blacklight
SO.... If your going to order all these bulbs, you'll want to get;
4 - 194 WLED-x-x LED bulbs (Doors & license plate)
2 - WLED-x6 LED bulbs (Map lights)
4 - Festoon 42mm 4210-xHP6 High powered bulbs (puddles & Domes)
4 - Festoon 4410-x9 LED bulbs (Dome switched lights)
Let me know if I forgot anything or need to add anything.
Good luck!!!
Nathan
Robert.K
San Diego, Ca
Just what I needed to know. How about the light under the hood? just kidding but if you really know I wouldn't mind knowing too!
---------- Post added at 09:33 PM ---------- Previous post was at 09:29 PM ----------
and the behind the dash/gauge lights!
2000Yukon
Nebraska
I'm pretty sure it's a 194 as well.
BOSS
The People's A D M I N
Dallas
That was a great thread, straight, to the point, and with pictures.
:waytogo:
B O S S
puckhead
CO
any tips for the doors and map lights? I havent checked but they look a little harder. Do you need to remove the whole door panel? and what about those footwell lights?
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
For the doors, all you have to do is pop the plastic light itself out. No need to tear apart the door. Takes 2 seconds.
For the map lights, you should see s little sliver of plastic missing where you can put a flathead screwdriver and pop it out.
puckhead
CO
thanks nathan! gonna give it a whirl when mine come in. Huck, they have their checkout kinda weird. you have to go to a product page, click buy now, then just click check out by any item. if thats not whats goin on then i dunno lol
LordGeek
Ohio
NathanJax .. excellent writeup, however, need to do a correct .. the size of the festoon bulbs are not 37mm .. they are 42mm .. that is what was installed in my 2002 Tahoe.
DenaliAK
Colder than you
Alaska
I don't have a light under my hood....or if I do it's missing. '03 Denali....should I have one?
vatahoelt
NoVa
I dont know what year you have but my 01 has rear door lights. If im not mistaken
04 tahoe lt. i took off one of the covers and there wasn't a bulb behind it. it was just a decorative cover.
my tahoe doesn't have one either. i think they stopped once they started making the nbs.
NOPROBROBB
UTAH
90 degree vs 120 degree LEDs
Does anyone have any comments or know what is better on the 90 vs 120 degree LED s for this?
Durobans
