07+ Lowering/Cornering Package. Autoride and Non Autoride Trucks..
NORCAL SS
SUV SUSPENSION GURU
Over the past month finally happy with the results on my 2011 Escalade. Driving the truck everyday and just going around the corners Im very pleased with the truck now going to offer a full package for those that don't want it slammed but a minor 2/3-4 drop and just a good cornering truck. I've installted this set up and sold this kit on here to many and it makes these trucks feel a lot more solid. If you tow you can also add the airlift 60742 helper bags to the kits below and will tow fine.
My 07+ Suspension/Cornering Package for Autoride trucks.
Front Belltech Spindles
Rear Belltech 5305 coils
Rear 1 inch spacers
Rear Autoride Links
Rear Belltech Shock Extenders
Front DJM Swaybar
Rear DJM Swaybar
Rear DJM Endlinks
Rear Bumpstops for free travel mod
$1025 shipped lower 48 states.
http://www.tbssowners.com/store/index.php?act=viewProd&productId=180
If you wanted to add in the Rear Spohn kit which would be panhard bar and lower bar in a del sphere set up would add $425 shipped (the upper arm you would have to weld the autoride bracket to so thats why I don't offer it but if you were interested in it still pm me and I can set you up)
My 07+ Suspension/Cornering Package for Non Autoride Trucks
Front Belltech Drop Struts
Rear 1 inch spacers
Rear Autoride Links
Front DJM Swaybar
Rear DJM Swaybar
Rear DJM Endlinks
Rear Bumpstops
Rear Belltech SP Shocks
$1150 Shipped lower 48 states
http://www.tbssowners.com/store/index.php?act=viewProd&productId=181
If you wanted to add in the rear complete spohn kit which would be the adjustable panhard bar/upper adjustable arms/lower adjustable arms in a del sphere mount design would add $650
As always if you have any questions you can post here or email me at [email protected] and if you need faster answers you can text or call me 24/7 also at 415 519 2432. Also if you see the items for less shipped I will beat anyones advertised prices plus back up my sales with 24/7 support
Thanks guys
Here is my 2011 Escalade with the above kit and also if you would like to see the complete build thread I did on it click following link >>http://www.tahoeyukonforum.com/forum/showthread.php?t=36707
soulsea
Bar
"Rear Spohn kit which would be panhard bar and lower bar in a del sphere set up" ...What does this do?
And the three things different from the basic kit are:
Front DJM Swaybar
Rear DJM Swaybar
Rear DJM Hardware kit
Swaybars I assume are to reduce body roll ... what does the hardware kit do?
Thanks.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
rear hardware kit fixes swaybar angle and I include new bumpstops
soulsea
Bar
Does the hardware kit work with the stock swaybar as well?
And what do the Spohn panhard bar and lower bar improve?
Thanks.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Thanks.
yes the hardware kit works with swaybar oem
the spohn bars are adjuustable/stonger and get rid of the rubber bushings that oem has. also when lowering you will see rear end gets sucked forward. You can push the rear end back and recenter it with these bars.
LADenali
Hey Tony, under what circumstances do you need to install lower control arm relocation brackets? Would you need them if you install the Spohn lower control arms?
Jmccormick
Can I ask a silly question?
Will this set up work on a 12 Premium with the magnetic ride?
Making sure there isn't any differences between the "magnetic ride" and "auto ride"
Thanks, Justin
JPeter
