03-06 Steering wheel conversion to 07+
Timmy
Brunswick, GA
what i have for sale is the 2011 steering wheel and airbag that i used to convert my silverado to the new style wheel.
Included is the steering wheel, airbag, and DIC plate so the DIC controls still work.
the wiring for the wheel has been converted to work with the 03+ steering wheel control wiring. i HAD the controls working, but the stopped for some reason, but they still light up so, i believe the control problem is on the truck end, not the steering wheel.
i also have the wiring to put the wheel back to stock so it can work in 07+ trucks as well.
$350 shipped. i have that much in the airbag alone.
CAResearch
Do you have directions to bypass the air bag warning light once you install the new one?
Also do all the steering controls work?
Curious about doing this mod
Timmy
Timmy
Brunswick, GA
There will be no airbag light as the airbag works like its supposed to. And steering wheel controls should work. I'm not positive, but again, they worked briefly on mine
Sent from my BlackBerry 9850 using Tapatalk
Timmy
Timmy
Brunswick, GA
You can't AFAIK. This is a dual stage airbag, the 01 is single stage
mohammadamlih
