syndicatesteve
Syndicate Steve
Step 1
with a razorblade, carefully cut around new gauge face to remove from packaging
Step 2
Remove left vent and right side switches & Vents with a wide flat blade screw driver
Step 3
remove dash shroud by removing the 4 small torx screws
Step 4
pull out the Gauge Shroud ( be careful not to break any tabs)
Step 5
Remove black Gauge face surround ( held on by 4 clips....gently pull and clips will pop out)
Step 6
Remove Gauge cluster by removing 4- 7mm bolts
Step 7
pull gauge cluster out and unplug gauges ( gear shift lever must be put into low or 1st gear...* make sure parking brake is set*)
Step 8
remove clear plastic gauge lens ( use flat blade screw driver to release clips)
Step 9 ** very important step**
roatate gauge needles counter clockwise as far as they will go ( gently, dont force) Then mark on supplied gauge diagram where the needles stopped)
Step 10 * be very gentle*
remove factory needles ( with a fork or for you golfers ...use a divot tool)
Step 11
remove factory gauge face ( be careful not to break the 2 tabs holding it on)
Step 12
apply new Nu Image Gauge face ( i used 2 small pieces of clear tape applied to each side out of installed view to hold in place)
Step 13
carefully apply either factory needles or New Nu Image needles ( press them on gently leaving 1/16" gap. install needles at 12 o clock position)
Step 14
rotate needles counter clockwise till the stop at full left position
Step 15
re-assemble gauge cluster snapping clear lense back into gauge housing
**** be careful and make sure all needles are properly aligned inside gauge cluster and not rubbing any part of cluster***
Step 16
re-install gauge cluster ** don't forget to plug cluster in** then turn on ignition to make sure gauges work before bolting back in
Step 17
Reinstall the 4-7mm bolts to hold in the gauge cluster
Step 18
re-install the gauge shroud using the 4 small torx screws
Step 19
re-install vents and switches
clip them back in place carefully
Step 20
Wipe down dash, gauge lens, and remove all tools
Step 21
Enjoy your new Nu Image Gauge face!!!
To see this product and many other styles go to www.nuimage1.com or call Frank at 951-278-2467 or email him directly at [email protected] tell Frank Steve Burkett Sent you!
or you can purchase the gauges from Custom Image Sound & Design 623-385-6366
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 11
Step 12
Step 13
Step 14
Step 15
Step 16
Step 17
Step 18
Step 19
Step 20
Step 21
