DRL's are now on low power. And then...
PlazaEJ
First off, let me apologize, for not taking enough pics.
What I've done is replaced the DRL light sockets with turn/park sockets. Both sockets take 3157/4114 style bulbs. My concern is, and was with the Avalanche, the DRL's use the high power side of these bulbs. As you will see from the pics, the heat from running these bulbs on high so much 'cooks' the sockets. And, if you change to Full-time DRL's, they get really cooked, really fast, and very brittle. I have actually broken sockets, just trying to replace bulbs, they're so brittle.
This pic shows the discoloration of the 'cooked' socket.
On the side of the socket that inserts into the housing, there are tabs across from one another that you must push in to get the center section of the socket out. After you get that insert out of the socket, you can see where the pins go into the base, and the ends of the wires, with the connectors inside.
Here's where I should have taken more pics;
Now, you can remove the wires from the old socket and insert them into the new one. The difference is, the Lt.Blue or Dk.Blue, depending on which side of the truck you're working on, get inserted into the center connector hole, instead of the outside, where you removed it from. The Black wire goes back into the same connector hole. This wasn't really that tough. It's the next couple of steps that take the work.
The alignment tabs and lock are only slightly different. You will need to make the one slot longer, the 12 o'clock position in the pics. A Dremel or file will suffice. If using a Dremel you'll need to clean up the burs, and square off the corner. Don't forget to blow/vacuum out the inside of the housing. Also, the outside diameter of the socket is just a tiny bit larger than the inside diameter of the hole. Dremel with sanding drum makes quick work of it, but a piece of sand paper will probably work. Just may take a bit longer.
This is the first one I trimmed. Wasn't a very neat job, but the socket fits just fine.
From here it's just re-assembly. Problem now is, it's dark outside and the DRL's won't light. Not until I get the FTDRL Mod completed anyway.
Now the "And then..." part of the title. I now have a high power element that's not being used. I could splice into the turn signal element, but that would just be a lot more light flashing the turn signal. What I'd really like to do is, find a way to wig-wag the DRL with its corresponding trun signal. Like the corner light does. The only problem is, I'm justy not quite sure how to wire that one. Relays and diodes are not out of the question, except that all the write ups I've seen for that require the use of the already lit DRL. And, I don't want the high power element in the bulb on all the time. Any electrical gurus wanna give that one a shot?
I'll try to get more pics, if I can. Especially, the lit DRLs, as low power.
EJ
P
PlazaEJ
If I can't find a way to Wig-Wag the high power side of the DRL socket with the turn signal, would it be possible to use "Switchback" bulbs, and have the DRL flash amber with the turn signal, yet still shine white for DRL?
Whatcha think?
EJ
P
PlazaEJ
The more I thought about it, the more I like the Switchback idea.
Ordered Switchback LEDs from v-leds.com.
Now, I can't wait.
EJ
Kenny1k6
Did you have to re-rewire the turn signals or DRL in a special configuration to get both lights to flash while using the turn signals? I'm looking to do the same with my '13 Tahoe...thanks in advance!
P
PlazaEJ
No additional wiring to the turn signal sockets. Only, the revamped DRL sockets.
From what I've read in this forum, there's probably a big difference in your '13. Check a wiring schematic, before you attempt yours.
EJ
Rivieraracing
EJ
So.....how have they worked for you? Did they solve your problem?
P
PlazaEJ
The only real problem was the sockets were always getting cooked, because the DRL's run on the high side of the bulb. Now, the DRL's run on low power side.
The modding part was just because I thought I could. And, that worked too.
I like the look.
EJ
stakerd
