Does a CAI really improve engine performance ?
dmannx
Carlsbad, CA
I've been reading through the forums and am on the fence about this MOD. I haven't found a clear cut feature / benefit from brand to brand. Everyone has their own opinion as to which is best. Most importantly - do they work - will I get more power ? as I read through the posts I see more people commenting on how good they sound. I could care less about what the truck sounds like. I just want it to know that it will improve the 5.3L performance.
On a side note, I recently worked a tradeshow for the RV industry and Magnaflow was right next to my booth. I asked the gentleman from Magnaflow working the booth what he would recommend for my truck. He point blank told me - nothing. The only thing it would do is make the truck have a good sound. Really ???
Most definitely. To sum it up and simplify things a bit, a good quality CAI will provide your engine with cleaner, less restricted, and cooler airflow. Less restriction and better airflow means snappier throttle response, a throatier sound, and potential for better mpg. Keeping the air as cool as possible is vastly important in making more power, especially on a N/A motor, and is why we place so much emphasis in our design on keeping the IAT as cool as possible. That is why we ceramic coat our intake tubes and offer an enclosed and insulated box design to reduce heat soak.
Also take a look at this, it was just posted in our vendor section today by a customer with our CAI. http://www.tahoeyukonforum.com/forum/showthread.php?t=44859
As far as the comments said to you by the exhaust guys, that makes no sense whatsoever. If more air and cooler air did not make more power then forced induction and intercoolers would not exist. More air means more fuel and more combustion, which means more power. Unfortunately they gave you very bad information, which is honestly quite surprising. Will a CAI add 50 HP...of course not, will it give you added performance that the average driver can feel and notice...most definitely.
Feel free to let me know if you have any questions, I would be happy to help!
MDC9966
Newton, NC
I can tell you for a fact. I drive pretty consistently. Some trips around town, a few on the interstate. Normal drivin, my mpg average is up 1-2 from just a CAI change. yes it has more throttle response, and when you play with that, your MpG goes down.
I'd do it again.
Denali0229
FL
I'd say the throttle response is better and sounds much better. I think it definitely has a little more power too. But my gas mileage didn't improve at all. I would do it again if I had the choice. It's a pretty cheap mod and easy to install.
Sent from my PC36100 using Tapatalk 2
doubletapdrew
Engines are basically air pumps, so anything you can do to improve airflow in or out of the engine will help make more power.
The factory intake is engineered to be quiet, and smooth airflow is a secondary consideration. Cat back exhausts usually don't add much (if any) power on the denalis since the factory exhaust is like a 3.5" diamater mandrel-bent setup and flow fairly well for a factory exhaust. I'm sure long tube headers would free up quite a big of power (they also tend to be very loud).
totheyard
Cat Backs add a little, taking away that stock muffler. Some back pressure is good.
MACHO
Seattle, WA
I've experienced 2 mpg increase with my aftermarket intake and exhaust. And the responsiveness and HP increase is defenitely noticeable.
felixgun
Lafayette, LA
I'd do it again.
Really? I noticed my mpg's slightly went down when I did added an Airaid CAI to my Tahoe I had... it had improved response when stepping on the gas pedal and it sounded cool but def didn't help my MPG's :/
Caddychris
