Rear view mirror "NOT WORKING"
saif najd
Hi
I started my new sub project wich is the "Rear view mirror"
I have the following:
1- an electronic Rear view mirror.
2- blug and wire ready and connected.
But it is dead 100% :banghead: nothing is working at all so I went to the local junk yard and tried 7 rearview mirrors and non worked from 99 models until 2001
This the blug diagram showing the voltage source.
As you can see only the middle is supplying the 12v and I found very week electric supply from the second pin a showing .6v or less
And I dont have the temp sensor as shown hear (red circle)
I took it from another thread (sorry for that)
Thanks
---------- Post added at 12:13 AM ---------- Previous post was at 12:01 AM ----------
I found this diagram:
The owner of this diagram he used pins 1 and 2 to feed the mirror to work.
Could any of you please take a picture of the wires so I can compare it to what I have may be the pins are mis placed?
---------- Post added at 12:17 AM ---------- Previous post was at 12:13 AM ----------
This another diagram but for the 16pin models
I need the same diagram for the 7pin model
---------- Post added at 12:30 AM ---------- Previous post was at 12:17 AM ----------
More info:
saif najd
saif najd
Great great info thanx bro I will do the work today to know whats wrong with my ride it seams I have a problem
---------- Post added at 01:37 AM ---------- Previous post was at 12:36 AM ----------
Is there a fuse or relay
---------- Post added at 02:16 AM ---------- Previous post was at 01:37 AM ----------
Just remembered the sun visor lights are not working too
Is there a fuse for it?? I need to know how the previous owner disconnected them
saif najd
saif najd
Last night I checked my mirror by supplying it with 12v external source and it worked :)
Today or tomorrow maximum I will start to traxe the problem on the tahoe
saif najd
saif najd
then follow the other pics to the convenience center to check those plugs.
I couldn't figure whats wrong with it I fiund out that the previous owner disconnected the sun visors so I connected them and they worked (solved a secondary problem!!)
I will take the roof down and see whats going on there
98 Chevy Tahoe 2dr Sport
DUB D
