5.3SLT
My wife’s 2008 Yukon (5.3 Flex) threw the P0449 code a few weeks ago. I first checked the gas cap condition/tightness and cleared the code with my scanner. Within minutes the code was back and I knew I was in for more than a simple twist ‘o the gas cap fix.
First up was the” Evaporative Emission Canister Purge Solenoid Valve”
AC Delco Part #: 214-1680.
Purchased this from a dealership for $31.00
This installed alongside the driver’s side fuel rail. Once installed, I cleared the code and was good go to……for about a week when the P0449 came creeping back.
Up next was the “revised EVAP canister vent solenoid valve (CVS) assembly and jumper harness.”
AC Delco Part #: 20995472
AC Delco Part #: 19257603
Purchased from Amazon for $40 and $15 respectively.
To access the old CVS, I backed the Yukon up on Rhino Ramps and placed jack stands in place as a precaution. I then lowered and removed the spare tire in order to reach the CVS and associated piping (hard line to EVAP canister and vent hose running up fuel filler hose. Hooked everything up, checked and cleared the code before replacing spare tire.
It’s been about three code free weeks so I’m pretty confident the CVS and jumper took care of it. I used the following as a guide:
TECHNICAL
Bulletin No.: 09-06-04-28C
TECHNICAL
