How to: Remove NNBS Headlights & change bulbs
04ctd
Charleston SC
You hear all kinds of horror stories about paying $260 for bulb replacement at the dealer, or having to remove the whole front bumper cover.
the lower outer assembly of the headlight is held in place by a 10mm bolt that is accessible via the front wheel liner.
you could probably do this by turning the tire, but I had to drill holes for the mudflaps. so I took the tires off.
you NEED one of these tools...i wrapped the end in masking tape to prevent scrathes
here's how to get the panel pins out:
start the edge in the grooove:
get up under it:
and get on it:
theres one panel pin in front of the front tire:
take out three panel pins, and two screws:
you can see the back of the DS headlight here:
you NEED a 10mm Box End Gear wrench, and you do NOT have to take it all the way out (but I did, so i could wiggle it around more)
masked off the front fender. you will wiggle the light around SO MUCH...you will scratch something.
there's two 10mm bolts on top
it comes out a little bit, but not all the way
the manufacturing tabs on the bottom catch the lip:
04ctd
Charleston SC
due to lack of space, i installed jumpers along with the bulbs, and put convoluted tubing on the wires to protect them as they went thru the radiator support:
I put the ballasts right in the corner, stacked them up:
here's the passenger side:
it that tapes look familiar, it's because i recycled it from the other side :)
here's the lower/inside mounting tab, you can see the back of it is open, so it will slide off the bolt, without fully removing the bolt.
I mounted the ballasts BELOW the air box plate.
I used Carb Cleaner on a paper towel to clean the mounting surface, and the back of the ballasts, and I trimmed off the extra sticky pad with big scissors, because it would just attract dirt.
I stuck the camera down there to get this pic:
I tie wrapped the wiring to the cross brace to keep it from hanging by it's own weight, and ripping wires loose.
I have found that most of the kits are the same chinese junk, no one better than the other, so here's the coupon that came this kit:
BEEMDUB
PIMP DADDY FLEX
Michigan
Nice...Theres already a writeup for removing the headlights though made my modded I think, but still good to know...Taking the wheels off make it a little bit easier but definitely a extra pain in the ass and make it take way longer...I like the way you loomed your wiring looks real clean!!
04ctd
Charleston SC
FWIW, those HID kits are crap, almost worse than the OEM Lighting.
with this much pain to get to them, I would def buy "retro solutions" and put in there.
wife wants me to pull these & replace them....uggg
Stevemo70
