Sway Bar Links After Spacers -Options/Pics
Screwd up 6
So after I lifted my tahoe I noticed the steering was sloppy particularly in the rear. The way i would describe it as "whipping". The back end whipped back and forth similar to a snake when making any movements at speeds over 50mph. After looking at the sway bar links I noticed they were at a horrible angle. I started to research tahoe sway bar links and noticed they were the same as jeep wrangler (JK). After taking measurements and contacting warrior products I confirmed the JK 3" sway bar links were the solution. The handling is much better. Pics and angles are below:
Screwd up 6
Screwd up 6
Bought them from Morris4x4 for $50 shipped. Looked up 5% coupon code online. Part number was WAR800039
Screwd up 6
Screwd up 6
I think these would still work with 2" spacer but after that I would look into another option.
01Konvict
Boats n Hoes
Raleigh/SML
Ordered a set today for my Kon, what bolts did you have to use to install the longer links? I plan on using stainless steel and maybe a lock nut.
Screwd up 6
Screwd up 6
For the upper bolt I used the stock one, and the kit comes with ones for the lower. Let me know if it makes a good difference on yours as well. I saw a night and day difference in handling.
Rvn9000
