Invision DVD headrest
LawrenceSor
Hey everyone, I'm new here.. I've been was on tahoeforum and was off the net for 2 months with a newborn baby. Now I'm back and I'm glad I was told about this site.. I just recently purchased new dvd headrest for my 07 tahoe LT. It's brand new but didn't come with good instructions. Anyone have a diy on this? I want to connect it to a power supply somewhere other than the acc. I hear there is an area to connect under the dash? If anyone has any info I would appreciate it. Thanks in advance.:hands:
Modded
That Guy
Depends on how much power is needed, you could use a pink ignition wire under the dash.
There are many that can be tapped into....
LawrenceSor
LawrenceSor
Theres gotta be someone on here thats installed invision headrests, pls help a fellow TYF member
elbison
Pearland (Houston), TX
I installed these on my 2008 Z71 Avalanche 4x4 LT3.
From what I remember, the plug-n-play powered hookup is near the hood release area (driver underside of dash). You might have to remove that panel, but it's been about 18 mos. since I did the install and i don't remember doing that. It might just be further up in there toward the firewall.
Everything was just plug and play. You put the control unit under the console tray.
---------- Post added at 08:53 PM ---------- Previous post was at 08:41 PM ----------
We have a sweet file cabinet......hope this helps.
CHINO07KON
MIAMI
Can't be any simpler than pics...lol..Keep us updated cause I have 2 9" on a stock navi but the picture has swirls..I even put a video booster and it got a little better..But the flip down went back to crispy clear..
B
b7cruiser
Is there a way to get the GM dvd heardrest system to run of the ACC instead of the ON position? I tried to move pin 8 to pin 7 but it wouldn't power both heardrests at the same time. I don't want to move to pin 5 (I think) because it will power the headrests all the time (even when the car is off). Also, when the key is OFF, this pin goes to 12.0 Volts and the screens won't power on as well.
Sorry, I don't mean to thread jack.
calieigh
calieigh
A small, portable DVD player can be mounted into the back end of a car seat headrest for back seat passengers to view movies. While some vehicles come with headrest DVD players installed, it is possible to install an aftermarket DVD player into a car headrest. Installing a headrest player can be easier than an overhead one, as you don't have to worry about mounting screws or headboards. The following directions are general, but they can vary for a specific player, so read over all instructions before beginning installation.
Johnson8537
Contact
Invision ask for
Brian Bagley-
1-877-468-4746 ext315
he should hook you up with install instucrtions etc. Nice guy!
bBARKER
Can't hook up on accessory circuit to much amperage too run both headrest. When you turn one on the other will shut off. Needs to be tapped into junction box down by hood release per the instructions.
---------- Post added at 10:31 AM ---------- Previous post was at 10:18 AM ----------
Pics before and after install Invision headrest are perfect
Tenn2033
