Anyone make led bumper lights/turn signals without amber?
tsb09000
Thread Killer
From what I can find, all new led bumper lights/turn signals have a mix of amber and white leds and I want some with all white. I hate amber!
Does anyone know if anybody sells them this way anymore? I've searched just about the entire internet to no avail... :throw:
I'm going to have a little front end make over this spring and these would really help.
Oh btw, not just led bulbs but the whole housing. Similar to these but without the amber leds. Sans reflector would be awesome as well.
tsb09000
tsb09000
Thread Killer
Well, I ordered these...
Seller said they have no amber.
I'll update when I receive them.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Interesting... definitely "off road use only" (not street legal) but no idea how they don't have amber reflectors or amber turn signals. Those are both a requirement to drive on the streets in the USA
tsb09000
tsb09000
Thread Killer
I've had clear lights without any amber reflectors and white lights for years and haven't had a problem. I'll probably get pulled over the day I put these on...
02 Burb
California
I know in California its legal to run white running lights and white turn signals, yellow is an option but not a requirement, look at all the bmws and audis with. The only differnce is for audis and bmws the turn signal is yellow.
i have the orange led bumper lights but i think either one looks good. Check out polobuds white led bumper lights
jomulk56
Resident Lurker
IN
I like the amber ones you posted first actually. You need some amber in your turn signal regardless of what state you are in. Most say than can be clear as a running light, but must omit amber when signaling a turn.
02 Burb
California
Turn Signal Lamps. 24953. (a) Any turn signal system used to give a signal of intention to turn right or left shall project a flashing white or amber light visible to the front and a flashing red or amber light visible to the rear.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
good try but keep going with that law...
California Vehicle Code Section 24953: Turn Signal Lamps.
(b) Side-mounted turn signal lamps projecting a flashing amber light to either side may be used to supplement the front and rear turn signals. Side-mounted turn signal lamps mounted to the rear of the center of the vehicle may project a flashing red light no part of which shall be visible from the front.
(c) In addition to any required turn signal lamps, any vehicle may be equipped with supplemental rear turn signal lamps mounted to the rear of the rearmost portion of the driver's seat in its rearmost position.
(d) In addition to any required or authorized turn signal lamps, any vehicle may be equipped with supplemental rear turn signal lamps that are mounted on, or are an integral portion of, the outside rearview mirrors, so long as the lamps flash simultaneously with the rear turn signal lamps, the light emitted from the lamps is projected only to the rear of the vehicle and is not visible to the driver under normal operating conditions, and the lamps do not project a glaring light.
So any side marker has to be amber. So that corner light needs to be an amber LED.
And it can flash white or amber, but you still have to have a yellow reflector
tygbenn
