jmitchell
- Joined
- Apr 3, 2014
- Posts
- 182
- Reaction score
- 4
Well I finally pulled the trigger and ordered some Yukon taillights to swap out for my Tahoe tails. I like the look of the Yukon ones much better and they seem to compliment my Tahoe much better. The actual physical swap was fairly simple and just as straight forward as it was for the late models.
I had assumed that the wiring harness would be a simple plug and play as well but I'm having some issues I need help with. Here is what is happening:
1. The night time running lights (LED's) are working perfectly (see picture below). These are both LED on Tahoe & Yukon.
2. The reverse lights (non-LED) are working perfectly. Both non-LED on Tahoe & Yukon.
3. The brake lights (LED) are running through the yellow turn signal lights (LED) right now, so when the brakes are applied the yellow turn signals glow solid. I believe the Tahoe was non-LED and Yukon is LED for brake lights.
4. The yellow turn signals (LED) are functioning normal for the first 3 blinks, then I get an error message on the DIC that says rear blinker error/failure while the blinker continues to work but at twice the blinking speed. I believe Tahoe was non-LED and Yukon is LED for blinkers.
Based on the information above and the pictures below, what are your thoughts to get this operating properly? I'm thinking that some of the wires are just crossed right now and I need to rework the taillight harness but I haven't done much troubleshooting yet. Any help would be much appreciated, thanks.
Below are a bunch of pictures with descriptions for the process...
Here are the Yukon and Tahoe tails side by side. They are the exact same size and shape...
Here is the back of the Tahoe taillight with wiring shown...
Here is the back of the Yukon taillight with wiring shown...
This black plastic retainer piece will come with each of the taillights. You will not need these since they are already installed on the vehicle under the taillight (see other picture)...
Carefully remove the black plastic piece that covers the T-10 screws for the taillight assembly. This piece is held on by 3 retainer clips. Carefully start from the bottom with a flat screwdriver and pull this piece out of the 3 clips. Leave the circular rubber piece in place (do not remove)...
Here is the back of the black plastic piece with the 3 retainer clips. With it removed you can now see the 2 T-10 screws. Remove these screws and keep them for reinstalling the Yukon lights...
Here is the pocket for the taillight with the taillight removed. You have 2 T-10 screws and 2 guide pins for each taillight. You can now see the black plastic retainer piece below the light already in place ready for the Yukon tail...
Here is the harness connection which can be accessed by laying flat on the ground from underneath the taillight. Would someone be willing to take a picture of this connection on their Yukon so I can see the wiring color order please?...
One of each installed (night running lights)...
Both Yukon tails installed (night running lights)...
Final product in the daylight...
