Leaking Chevy 22" rim
Blumax
I have one wheel that continues to lose air very slowly. I have had the tire checked and nothing has been found regarding the tire. The only thing left is the wheel itself. There is no damage to the wheel on the outside or inside. Is there a fix for this other than replacing the wheel?
yates ™
Resident Apple hater
Iowa
Have had the valve stem replaced? If tire and wheel were bubble tested it should have shown a leak unless it is very slight. How quickly does it leak down?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
x2
they can put some good psi in the tire and dunk it into a tub of water and it should show it leaking somewhere.
OHSIXX
Milwaukee
I was losing 5-6 PSI a day with one of my wheels and ended up replacing the valve core. Easy to swap and cheap...ran about $3-4 for a pack of 4 cores. And the tool was $2.
B
Blumax
It takes about a week for the DIS to show a low tire. The tire pres listed on the DIS and it's accurate. I had it at a dealer and was told they couldn't locate any problems with the tire. I've used soap suds on the valve stem but no bubbles.
---------- Post added at 12:47 PM ---------- Previous post was at 12:45 PM ----------
x2
Just wondering so I don't make the same mistake twice. Is there a rule that addresses the same issue, asking for help with my tire, on two different threads?
---------- Post added at 12:49 PM ---------- Previous post was at 12:47 PM ----------
Excellent suggestion. 6 Bucks and a few minutes to eliminate the core as the problem. Thanks for the help.
yates ™
Iowa
I would try changing the core first then have the tire reseated (not sure if I am saying that right. Out of everything I would say the tire is the least likely part to leak. That small of a leak will be harder to find and very unlikely to show with soap bubbles, need to dunk the tire and wheel in water.
---------- Post added at 11:53 AM ---------- Previous post was at 11:50 AM ----------
It clutters the forum with needless multiple threads. If you post a question in a thread then please bump the old thread, sometimes certain people with the answer do not see it the first time.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
this...
And if you do the dunk test, it might show the leaking around the sensors/stems. My wife's old pathfinder leaked around 3 of the stems and had to get replacement O rings for the stems. If you can't find anything leaking with the tub test, I'd look at the stems.
Mr. Merk
If it's chrome, they tend to develop corrosion along the bead. If this is the case you'll have to dismount the tire, have it ground off with a wire wheel and then have tire sealer applied to bead before re mounting.
This is pretty common on Escalade chrome 22's, the Chevy 22's were made in the same factory iirc (same town I work in) and my friend's Saab 9-7 5.3's SILVER 18" wheel also had the same problem.
The moisture in the compressed air just causes the chrome plating to deteriorate and rust. Your wheel isn't actually rusting so don't worry about that.
OHSIXX
Milwaukee
When I had my new Nitto's put on...my mechanic buddy did exactly that. I had alot of corrosion around the bead and he hit it with a little disc grinder(actually I did the grinding/sanding while he worked on mounting the tires).
Wngrydr1
