Question about lift and tires.
willem
I got some spare 285/70r17 cooper tires on OEM 17” lt wheels, and i was wondering if they would fit on my 2003 (4wd) tahoe if i would buy something like this: http://http://www.ebay.com/itm/2000-2006-GM-1500-SUV-2-5-FRONT-1-5-REAR-LEVELING-LIFT-FEATURING-BILSTEIN-/161624357340?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ATahoe&hash=item25a18ff9dc&vxp=mtr Parts for a tahoe are kinda hard to get in the country were i live so rather know for sure it will fit or what betters options would be.
My apologies for my English since I’m not too good with it.
owl_93
Your link seems to be broken. But in the URL i saw something mentioning Bilsteins and a Level kit. If you level with keys and spacers and z71 coil springs and bilsteins, you can fit 285/70's. You will need to bring the front up 2.5" or so and add 1-2" spacers with the new springs your should be fine. My tires don't rub at all and they are 285/75/16r, which is the same overall height and width as yours.
W
willem
Thanks for your reply. The set includes 2,5" keys, 1,5" spacer, bilstein 5100 front and rear shocks. So only need to get additional z71 coil springs.
owl_93
That sounds right.
Here is what you need...
Front shocks: Bilstein (24-186643) 5100 Series Shock Absorber https://www.amazon.com/dp/B00BYNJAVW/ref=cm_sw_r_awd_m-R-ub1HW0M01
Rear shocks: Bilstein (24-185783) 5100 Series Shock Absorber https://www.amazon.com/dp/B009FU66FO/ref=cm_sw_r_awd_baS-ub104YG2C
Coils: Moog 81069 Suspension Coil Spring https://www.amazon.com/dp/B00498ZR7A/ref=cm_sw_r_awd_YaS-ub1K4D3TH
Keys: 1" - 3" Torsion Bar Lift Keys Chevy Half Ton 6 Lug 4x4 Trucks https://www.amazon.com/dp/B00BEN1PXI/ref=cm_sw_r_awd_QbS-ub103YDWK
Spacers: 1.5" Lift Rear Axle Coil Spring Spacers Tahoe Yukon Suburban https://www.amazon.com/dp/B00BEN3BEY/ref=cm_sw_r_awd_LcS-ub0YPNVHA
Sent from my Galaxy Note 4 via Tapatalk for Android
owl_93
Great! Post pics here after you get it installed! Hope it works out for you. Cheers
05tahoeguy
upstate ny
owl, sharp looking truck!
i was just reading your amazon list.... and was wondering if that set up would work on my 05 tahoe? also is that the set up you have on your tahoe?
owl_93
I think it will. What suspension options do you have? Autoride? Z71?
05tahoeguy
upstate ny
bro, i honestly have no idea, its a stock 05 tahoe, lt, with all bells and whistles. i picked up cheap with 215k on it and all records clean. so i am thinking about making it my toy/money pit. currently on 17" stock rims and tires with a set of 275/55/20 in the summer.i want to put some more aggresive tires on the 20's and maybe even the 17"s for winter. i like the way your tahoe sits, and would like my like that.
owl_93
Chances are this should work just fine. The only thing is, if you already have the z71 package, you don't need to buy the coil springs, unless you wanted to replace them. With 215k, you might as well spend the extra $60 bucks for the coils.
Mine had the autoride (automatic air leveling by increasing pressure in the shocks) and my shocks were blown.
Look for the badge on the side of the truck between the rear of the back doors and infront of the cargo side window. It should either say "LS", "LT" or z71. Im guessing you would know if it were a z71...
shanersutherland1
