Left turn signal turns on hazzards!
tsb09000
Thread Killer
I'm hoping I have found the answer online already but wanted to see if anyone else has had this problem before I spend the money. Basically, about 80% of the time I turn on the left blinker, the 4 way hazzards come on...which really sucks.
What I've found online is to replace the flasher module with the new part number 10383321. This is located on the back side of the fuse box on the left of the dash.
So has anyone else had this problem or heard of such a thing? Is there any other way of testing anything?
Thanks!
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
haven't heard of it, but the methodology is sound.
the place where they normally could come in contact/ cross would be the flasher...
OR in the wiring harness where the column pivots.
tsb09000
tsb09000
Thread Killer
I hope I'm not jinxing myself by posting this but I've had the new flasher module in for a few days now and so far so good. It is a little louder than before but it's a hell of a lot better than turning left with the flashers on!
Hope this helps somebody out!
Eagle
EL PASO, TX
lol, you are in the <2007 section!
zeevon3
