The 4 Hi mod for a 2000
withac
Eastern Idaho
This will leave the low beams on when you turn on the high beams, real nice. I think this method works up to the 2002's. I think from '03 and up you use a different method where you jam diodes in the fuse box. Maybe someone else will post up on that one.
I'm having a hard time telling where to put these. I put the fog light mod in the inside section because the mod was done inside. This mod is done under the hood and behind the lights. Since the lights are outside I put it here. If a mod wants to put them both where they belong feel free.
I know there are lots of posts on the 4 Hi mod for the earlier models but they’ve gotten pretty lengthy and confusing so I thought I’d post up how I just did mine. Hopefully this will make sense and put everything together in one post. I’ve drawn from the other posts as well as from some questions I’ve had answered, so thanks to everyone who has contributed on the other threads.
From Jkmotorsports: Pre-03 models
Behind the driver's side headlamp assembly, locate the harnesses to the low and high beam bulbs. The low beam should have a yellow and an orange wire. The high beam should have a purple and an orange wire. When buying the relay, JKMotorsports says “Ask for a typical SPDT automotive relay, such as those used in some aftermarket driving/fog light systems. These will have 5 contacts labeled 85, 86, 87, 87a, and 30. You might have better luck going to your local stereo/alarm shop, as these are always used , especially in alarm installations. They'll know exactly which one to give you; the type used in aftermarket automotive integration are basically industry standard.”
A friend who installs car stereos and theft deterrent systems sold it to me for five bucks.
The first pic shows the basic materials I used. Relay, wire, shrink tubing, insulated crimp female connectors for the relay, dielectric grease, and I forgot to include the uninsulated crimp wire connectors.
First I crimped 18” of wire to the female connectors, using some dielectric grease on the wires. To help keep out moisture I then put some shrink tubing around where the wire enters the connector. It wouldn’t shrink tight so I used a smaller size over the larger. Getting it over the larger was a pain. I didn’t have wire colored to match the lights so I used different color shrink tubing on each to help identify them. The second picture shows this.
First, I wired the relay following the third picture (thanks FergHoe) and you only need to perform this on one side of the vehicle (thanks JK).
I did this with wire taps to make sure I had it right before making it permanent, see picture 4. To help keep it dry, I kept the relay in the engine compartment and threaded the wires through a gap to get to the headlight compartment.
Once I knew things worked like they should, I removed the wire taps and cut the headlight wires where the tap had nicked them. I used dielectric grease on every crimp connection. I then stripped enough headlight wire to insert into the uninsulated crimp connector. I fanned the headlight wires out so I could intertwine them before twisting them together, hopefully giving a better, stronger connection, see picture 5. Crimp the twisted headlight wires in one end of a crimp connector.
Next, slide a piece of shrink tubing up the appropriate wire coming from the relay. Strip and crimp this wire. Since the two pieces of the cut headlight wire are now side by side, I took a small zip tie and tied them together to help keep the strain off the shrink tubing or the connector.
Picture 6 shows the orange wire with the shrink tubing in place and the yellow and purple wires with the bare connector and the shrink tubing slid up the wire.
The 7th pic shows the shrink tubing in place.
Next I stuffed the wires back in the factory wire looms and taped them up with electrical tape like they were before I started, picture 8.
Lastly (picture 9) I mounted the relay (it had a little mounting tab on it) and grounded out the ground wire using a bold from a support just next to the battery.
I can only put five pics in a post so I'll put the rest in the next post.
withac
withac
Eastern Idaho
Here's the rest of the pics.
jmildoc
Indianapolis,Area
that is alot of work. I wish I could have shown you mine when I did it. All i did was take the electrical box up and tapped into a yellow wire and grounded it. It took all of 5-10 minutes. And I didnt have to buy all that stuff you had to get.
withac
withac
Eastern Idaho
It really wasnt that bad, plus I enjoy messing with stuff. Actually somebody did post up back then about doing it the way you did. I don't know enough about electrical systems and I was worried it might cause some problems, I felt better having a relay in there. But then I guess how I did the fogs is basically the same thing huh?
Eckl
Hey thought I'd share and alternate method as mentioned above. Credit given to another forum....
"Well, it took a while but I finally found the info I needed. As I suspected, the yellow wire at the back of the low-beam bulb is connected to the popular yellow wire under the electrical center. The yellow on the low beam and the purple on the high beam are alternately switched to ground by the dimmer switch. If the yellow wire could be permanently grounded, the low beam would stay on when the high beam is switched on. The grounded-yellow-wire-under-the-electrical-center trick accomplishes this, but...
The easy all-on mod FOR A 2002 is:
1. Remove the two pins and pull the headlight assembly forward a couple of inches.
2. Use about a 1' length of approx #16 wire to tie into the yellow wire going to the low beam bulb.
3. Ground the other end of the 1' wire. There is a handy fender bolt a few inches back from the headlight.
4. Re-install the headlight assembly.
Done. Took less than 5 minutes on my truck and works fine.
DO NOT ATTEMPT THIS WITH AN '03+
No, seriously, DONT !!"
Mr45
Florida
That's what I did. Re-ground the yellow wires behind my lows.
LordGeek
Ohio
Eckl .. do you have any pics of this install ? and do you have to do this on both sides or just the driver side only ?
I have a 2002 Tahoe in which I've been looking to do this with .. definately beats buying a $ 40 kit from LMCTrucks :emotions122:
jESse
i like cheese
michigan
do you cut the yellow wire to send it to ground or just use a wire tap for example, to connect another wire to send to ground? probably be doing this on a friends yukon this weekend. just wanna make sure i'm 100% on the details before i go chopping away. lol
CoyotesRUS
