97YukonNZ
Steering idler had been on the way out for sometime but hadn't worked out where the movement was.
wasnt hard to get out and arm was an easy split.
Replaced with an AC Delco supreme fro R.A Am impressed with DHL yet again. Got it over here to New Zealand in No Time!!
97YukonNZ
You definitely lucked out with the removal.
Yes I sure did luck out!
I watched a removal on YouTube and that backed up what I thought I had to do.
And very lucky i had replaced the steering bar a couple of years ago so the arm wasn't seized in there.
Learning lots and getting jobs done to make her safe and more fun to drive.
Cheers guy's for any help you've given.
east302
Mississippi
Not my Tahoe, but the transmission in my 98 Z71 gave up the ghost this morning. When pulling out into traffic it gave a loud bang and no longer has reverse. I got it towed into the shop.
I’m assuming it’s the sun shell but will see what the rebuild shop comes back with. It made it almost 200k miles so I guess I can't complain.
By 8:00 this morning I was ready to call it a day, lol.
97YukonNZ
I purchased some wee mud flaps and put them on in the weekend. Going to see if they help keeps a bit off the side of her20240306_155857.jpgAlso replaced the swaybar bushes and link rods. Someone had replaced the original with the wrong size rods and the sway was not functioning properly!20240306_155920.jpgfeels much better up front. Am looking forward to getting the new arm bushes in at sometime. Grabbed this master set from R.A20240306_160029.jpg
Izzythoed
I changed the water pump on my 99 Denali bought it a two weeks ago from an older gentleman said it was sitting for a year or so the water pump went out had a really bad leak left me stranded ended up changing the radiator cap flushed the coolant changed upper and lower radiator hoses man were they crunchy asf but now I'm back on the road waiting to do more to it
97YukonNZ
I dont know if anyone has done this.
I recently replaced my tires to a lower profile and as a result needed to change the spare size to the same.
20240318_141712.jpgAfter lifting the spare back up into position I decided I wanted to do something to change the look of a spare hanging out of the back so I found a cheap leather look vinyl cover on a local trade site.
It cost me $8N.Z to do or $4 ish U.S.
It is a snug fit and tucks up underneath when the spare lifted into place.
Have done 1000 or so miles and it hasnt moved so I think I'm onto a winner there.
Dukk
