How to: repllace upper & lower ball joints on NNBS Tahoe
04ctd
Charleston SC
take the wheel & random parts off:
hang the brake caliper by the BRACKET, it will hang there for a long time, and be out of the way.
DETACH the ABS wire...or you will stretch it, rip it..something. I messed mine up somehow when i did my lowering kit...and then, it cleared up on it's own.
you have to detach the sway bar so you can move the lower arm around
you will have to remove the strut
in order to get the upper control arm bolts out, otherwise, they hit the spring.
I had to heat, beat, pickle fork, heat, bang, and smash this ball joint to get the spindle off it:
the lower ball joints are pressed into the lower control arm, and they have four areas that are peened over the edge, you have to grind them off:
there are SO many parts & nuts & bolts, when you take something off,
thread it back on where it goes...that is so much faster than digging for parts.
FWIW, i think you need a 21mm, a 22 for lower BJ, 18 for upper BJ
19 for brake caliper, and i had 15mm on sway bar & strut tabs.
go to Advance, get the "Master Ball Joint Kit"
it's $99 to rent it, and they refund that to you, but it takes a few days to come back, so beware.
the whole thing is jenky, i finally had to tape it together
04ctd
Charleston SC
at one point, i had to hold the removal rig with my foot to keep it from shaking off
the cup that fits over the rubber grease boot is too big, it slipped off.
i tried the next smaller size
i had to remove the rubber boot, and then put a smaller press cup on the rig to press it in.
PB Blaster was flowing like flatulence at this point, i put some in the hole on top the new ball joint, to act as cutting fluid.
i could NOT get the top of the BJ up far enough to put the cir-clip on it.
and pretty much, it was getting late, and I did not take many more pics.
the replacement BJ did NOT have to have the bolt cut, it was short enough to clear the rims.
here's where my upper control arms are set for proper camber, NOTE: you have to break out the OEM plastic to move it
here is the kit I used:
http://www.ebay.com/itm/320981191502?item=320981191502&viewitem=&vxp=mtr
macautopartsdiscounts
Price:US $229.99
$30.29 Standard Shipping
NathanJax
Vacation Nathan
Administrator
Jax, Fl
nice write-up
Modded
That Guy
Very nice write up Joey. It should be made a sticky.
Also, the upper ball joint is a lot easier to remove if while the suspension is still loaded, you remove the tie rod first, then loosen the upper ball joint bolt partially (NOT remove the whole way or the assembly may fall), then give the area around the loosened bolt a few wacks of a mallet.
04ctd
Charleston SC
tks, you reminded me: basically, i took everything loose, but left the nuts at the end of the threads so it could not all fall apart.
and I put it together the same way, like if you tighten the upper control arms, you can't move them around.
quick note on the Uppers: the grease bag/rubber boot was attached to the Arm, and to the spindle, so when I hit it with the impact, it ripped the boot apart.
you HAVE to hold it with an allen wrench, and use a 18mm Gear Wrench to tighten it.
this is a JOB...but it is very satisfying to do it yourself, and i bet it would cost a fortune at a dealer.
jz57
Since you were there and all the front suspension parts were removed, why you did not replace the lower control arm bushings?? Defficult to get the bushings in parts store?
Gzes
the drifting 2dr
Wichita tx
They should be alright i mean its a pretty new suv. Howd you kill the bj so fast?
04ctd
Charleston SC
roads are just asphalt over sand here, get some rough stuff
previous owner was medical rep (door to door sales) i guess he beat it up.
FWIW, if you could buy whole new arms, and get the BJ's & bushings all done, would be MUCH easier than pressing the BJ's out.
12rtstp953
By saving those plastic inserts on the control arm cams....the alignment would have been close enough....
Nice write up... I use a snap on ballpoint press where it all snaps together ..no need for tape
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I need to do mine. Right Lower joint is creaking when going over bumps and turning
2012denali
