Wiring Schematics 2015+
Turbotoys
Minnesota
Here are the wiring schematics for the Stereo and Amp. If anyone wants any other wiring let me know and I will post em up.
Radio
Amp - it is located behind the jack bracket in the rear of the vehicle.
Anon2015
Very interesting. Multiple subwoofers in the same room (vehicle) perform in some very interesting ways when given the same signal. This is a common technique used to clean up modal response problems. The remaining question is which one, or both, are being used for ANC.
Rush
NC
We definitely know T3/X1 is being used. Don't know about the others.
T
Turbotoys
Minnesota
Fog Lights
Here is the Fog Lights
---------- Post added at 08:13 PM ---------- Previous post was at 07:52 PM ----------
There is only 1 Subwoofer - if you look at the diagram above there is only 1 positive and a negative for subwoofer. There must be a misprint or they are using a postive signal from the one side and a negative from the other side to sum a mono channel to the subwoofer.
Look at the following sheets - no mention of a second subwoofer.
blackout07
Beaumont, TX
Thanks. Rick. Looking at the fog schematic, does that more or less mean that the fog lights are controlled by the BCM? And wiring after the fact would be more complicated and require programming?
T
Turbotoys
Minnesota
Im pretty sure everything is controlled by the BCM :jester:
Are you trying to add factory fog lamps?
Phoenix111
