Denali cluster upgrade in a Tahoe
mrathell
Has anyone upgraded their cluster to the Denali cluster?
I have the 2015 Chevy Tahoe LT and wanted to hear if anyone was happy with their purchase. I'm considering doing it. I found these two companies that do them. which one did you guys use?
homeys
I'm very sure that Coastal Flash is out of business. You'll see on the GM-Trucks forums that they haven't been returning calls, I'm not exactly sure what happened.
I've done my own cluster swap on a 2015 GMC Sierra to a 2018 Denali cluster. I did this because I added Apple CarPlay/Android Auto and by putting a newer cluster in, it adds the steering wheel control to command Siri (it runs through the cluster, believe it or not!). I did it all myself but it's not easy at all! I can tell you, WAMS is good at what they do. You'll be happy with it from them. It will be plug and play from them.
Uspsmailman
Newbie so I bought a Denali 2018 cluster off eBay if I plug it in my truck what happens ? Security?
Uspsmailman
I bought the cluster can I just swap it or will it put my truck in security mode ?
ChuckWoodChuck
