Ac problems
Keonsr10
I have a 2008 Tahoe Ltz one day my ac would only blow cold out of driver side and controls wouldn't change from vent to defrost. So I replaced control module and all actuators as well as did the reset process. Its blowing heat on both sides but not as strong on passenger side also it still will not change vents or cool.
Geotrash
Dave
Richmond, VA
Gotta get a good scan tool on it that can read the hvac module and tell you what the doors are being commanded to do vs what they’re actually doing. Did you use GM parts?
A new control module must be programmed to the vehicles, they are not plug and play. The Apple Car Scanner app can read BCM codes on IPhones. If you have one or access to a bi-directional scan tool, pull up the internal BCM codes. It will tell you which actuators are bad and why with the symptom code following like, B0413 61 or B0413 05.
Having said all that, your Mode Actuator is the likely culprit here, it's the one in the driver's footwell. Aftermarket sensors don't last, buy once, cry once, for GM OE/ACDelco, same box or wrapper with both numbers.
K
Keonsr10
All actuators are brand new and still not working I've done the reset process 4 times still nothing. These are the codes it keeps throwing.
K
Keonsr10
I purchased aftermarket off amazon
mikez71
Any updates? Do the actuators move when doing the calibration?
K
Keonsr10
Update:
cervantesjesus174
