RooTBeeRthe1st
I can't imagine the commitment it takes to drive something that low around Louisiana roads.
that low life or no life I guess
It's bagged. Aired all the way up, it's higher than stock. He has the ride height pre-set, but he actually can drive and turn with it as low as physically possible. He doesn't drag it and all his wheels clear. That's more than I can say about mine.
Geoffsfas10
St. Louis
Swapped into the new camposition sensor tonight. Not too bad a deal overall. Was actually easier to pull the intake tube and go at it from above with a long shaft flat head. The old came out in pieces, so maybe it was what was actually jacked up. I drove it around the block and then went grocery shoppi g. So far no light, fingers crossed its good tomorrow. I should know quick since it was all sorts of unhappy today before the sensor
blackelky
Ordered GM Part # 15055343 and 15055342 and the dorman hoses with metal y Dorman 626-553. Because Doubeleive
scared the **** of me that they're going to fail soon lol. Hopefully get them swapped out Friday
Now the temp guage fluctuates between 210-230 hopefully the air is just bleeding out of the system
dboric
