I cannot learn the Schrader 21507 TPMS sensor in the Tahoe 2007
DJPoertsch
Hello dear community.
I bought new TPMS sensors from Schrader model 21507 for my Tahoe through Rock Auto. In the past, I always had some cheap ones from Amazon or from China. Either the batteries were empty after 1 year, or, as is currently the case, the entire sensor unit was simply lying in the tire.
So I wanted to spend some money and bought 8 pieces from the Schrader company. Now I wanted to train them like my old sensors with the EL-50448 tool (orange). But nothing happened. I read in the description that these are already pre-programmed.
What am I doing wrong here so that I can get this programmed into my ECU? It didn't work with the relearn button in the Tahoe and the horn signal. Do I need another tester, or could I do it with my Tech2 software? Maybe there is a completely different method that I don't know about. It would be a shame to have spent money for nothing again.
Thank you very much for your help and greetings from Germany, Markus
Geotrash
Dave
Richmond, VA
Hello again, Markus! Welcome back. I use a special tool for mine: https://a.co/d/a7cdIvu
It’s inexpensive and designed for the purpose.
petethepug
Michael
SoCal
The tool makes it super easy and something you’ll want to have as part of your permanent tool arsenal.
You can google the user manual or use the one that came with the truck to see the instructions on how to set the TPMS by lowering the tire pressure but it’s a PITA until you master it.
Only the 07-09/10 have that feature otherwise you’ll need the reset tool.
DJPoertsch
DJPoertsch
I tried the sensors with the same tester as you described to me. Nothing works. I also pressed the relearn button and deflated. That didn't work either. ‍♂️
DJPoertsch
DJPoertsch
As I answered above, I have this tool lying around in the car. I also put in new batteries. No matter where I put the nose of the tool down, I don't get a honk signal. Not even when I deflate the tire. ‍♂️
I am assuming that you bought the correct sensors for your year truck. I believe that sometime in the mid to late decade (2015-2020) they changed the frequency on which the TPMS sensors operated on.
DJPoertsch
DJPoertsch
DJPoertsch
DJPoertsch
Amazon wants 2 or 4WD and a body code to verify fitment.
Unfortunately, I order from Germany and have to rely a lot on the specifications here. Amazon is not the place where I like to buy spare parts. Especially since many fakes are sold. I have now sent a message directly to Schrader asking for clarification. Because somehow you have to be able to trust as a customer, especially with RockAuto
JVega
