Doug118
- Joined
- Sep 22, 2012
- Posts
- 522
- Reaction score
- 979
For you guys trying to figure out voltage issues with these trucks, you can just unplug the current sensor and your voltage will always stay between 14-15v depending on the weather. Mine has been unplugged for 5 years with no issues
Or if you want a different solution that allows you to dial in exactly the voltage set point you want, this is what you need
Voltage PWM controller based on Internally Regulated Alternators PCM CONTROLLED 05+ GM vehicles
This is a voltage knob made for PCM controlled 05+ GM vehicles with the small rectangular 2 pin plug. It makes it plug and play with the GM 2 pin harness. There is no splicing of your stock plug required. These are generally in stock and ship within a couple of days of purchase. They work on up...
brand-x-electrical.myshopify.com
