Since i bought my 2016 Denali i didnt like low/hi beam and fog light setup
So i ordered Uxcell PSX26W 30w 6000k led
On driver side is Uxcell 6000k foglight, on passanger side is my other option fog light Xenon Depot 5000k led
Next pics is comparison pics of OEM Osram D3S lows with Uxcell 6000k fog led on driver and Xenon Depot 5000k on passanger side
Next pics OEM D3S lows with OEM 9005 Hi beams
Next pics is OEM OSRAM D3S 66340HBI rated 4300k or 4650k
Next is TRS Morimoto D3S 5500k
Next pics is TRS Morimoto 2Stroke 9005 6000k led for hi beams
Since i didnt know if TRS 9005 led is gonna work i didnt wanna mess up OEM headlight low/hi beam bulb cover, i bought 4 new ones part# 22941303 on ebay $4.15 each. Also TRS 9005 leds comes with extended rubber caps and i use them on moded OEM caps
I use Lenox 2 1/4 hole saw from lowes part# 348138 and drill about 3mm off center on bulb covers since Led will be close to this cap, and i use black RTV silicone to seal rubber cap to OEM cap
Here is how rubber cap looks like after everything is installed. I did pull male 9005 connector out and connect it to Morimoto ballast and tuck/zip tied
I used Scotch outside red double side outdoor tape and attach ballast under low beam bulb housing
Next pics is Xenon Depot 5000k led fogs
Next is Xenon Depot 5000k led fogs, TRS 5500k D3S low beam on driver side and OEM D3S on passanger side
Next is TRS D3S 5500 lows on driver side, OEM D3S on passanger side
Next is TRS D3S 5500 low on driver side, OEM D3S on passanger side, TRS 9005 hi beam led on driver side and OEM 9005 on passanger side
Next is TRS D3S 5000k lows on both sides
Next one is TRS D3S 5500k lows with Xenon Depot 5000k led fogs
This pics is TRS D3S 5500k lows with TRS 9005 led hi beams
