I have a 98 2door tahoe with 4wd. Right now the hubs are off cause I just replaced all ball joints. Should I do anything to the hubs/bearings. Truck has 230k miles. No service to bearings that I know of. They seemed to be working fine with no wierd noises or grinding. Just wondering cause now is the time to do it while the hubs are down.
I've researched a little here and the general consensus is to leave the OEM bearings alone till they start causing problems.
Can I just pull the bearings and repack them or are they a sealed unit. When I pulled the hubs, the bearings had some blackish, worn out looking grease on inside face. Maybe that old grease came from me removing the stud of the lower ball joint from the hub. I had to tear up the grease boot of the ball joint when using an old crappy pickle fork.
What do ya'll think.
