Lowered/AC forged 24" wheels/Wilwood big brake kit Finished
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
My custom lowering kit $675 shipped
Wilwood Big Brake Set up $4000 shipped
AC forged rims with tires/sensors $6000 shipped
I can get it all for you and truck stops so much better now
davidpark06
How many inches is it lowered front and rear and what size tire? Looks good
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
305 35 24 and this is 2/3.5. this model had the higher spring rate in front which sits higher then other rates gm used
TechSupport
Which brand tires did you use and how much more for 26s”?
Oh and do the Wilwoods fit with stock 22” Platinum wheels? It does snow here in New England
CMoore711
I have the Norcal 1-4.5" Rear Adjustable Kit http://www.tbssowners.com/store/index.php?act=viewProd&productId=578
What exactly is used in the rear to achieve the 3.5" drop seen here?
Use the 5/8" Heater Hose and not place back in the stock upper spring insulator?
Is this with the 1" Rear Spring Spacer installed or No?
Also you mention that this Escalade has the higher spring rates that GM used compared to other SUV's, and in other threads I think you mentioned that there are two part numbers for the springs one ending in a 7 and one ends with a 2. Do you know which one is the stiffer higher spring rate, ending with a 7 or the 2?
Thanks.
guy from norcal
Looks really good.
I bet she stops 100x better with bigger brakes and lighter wheels.
Squirrely tahoe
