S33k3r
The sending sensor for my 2005 Suburban is bad. Everything I've read has indicated that I should replace the pump when the sensor is replaced -- the pump has to be removed to replace the sensor. Going forward, I am not planning on adding a bunch of power to my system, but would leave my options open.
That said, which pump should I get?
I'm thinking I want to get a Flex Fuel pump (AFAIK, I do *not* have a Flex Fuel engine), because 1) it potentially puts out more fuel and 2) it will be more resilient to the alcohol in normal gas.
Can you please offer any suggestions you have, or experiences you have with various pumps?
Thanks.
Thanks.
