LMAO, yes she is lifted again... I replaced the valve cover with the upgraded design and replaced both valce covers with Fel-Pro gaskets. It seems to have stopped my oil leak and hopefully my oil consumption issues as well :)
Looking forward to an update on this. I think I still have the original valve cover on mine. It'd be nice to know I still have one more trick to try.
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
I have a viper 5906v with smart start cellular module, gps tracker module, tilt sensor, glass sensor. it is a color oled fob with 1 mile range, viper phone app. I can be in Africa and start my car here, lock, unlock, pop the rear hatch. I have had this system and the previous models since smart start came out and baring a couple of minor glitches (on previous models) it works great.
if the alarm is triggered it signals the fob which has sound and vibration, and sends me a alert thru the app and records the alert in the app. the only thing I don't like about it is the current fob buttons are very sensitive and will depress in your pocket if you have it in a pocket with anything else, it does have a keylock option which helps but it will still buzz at you if the buttons are depressed in your pocket. a little annoying sometimes till you move it a little but I'd rather that happen then go out to a ****** up truck because some tweaker had to have my dvd system or wheels. on my old nbs if they ripped out the system usually it would cost another $500 to have the shifter fixed on top of anything else. it's not cheap to have installed and there is a yearly subscription for the smart start but it's worth it to me. I had mine set to sound both the viper alarm and the truck horn and I have added a internal high decibel siren (somewhat like a **** alarm) so even if your dead asleep it will wake you up and half the neighborhood.
Great info, thanks! I’ve been too afraid to put any decent electronics inside my truck for fear of break-ins. I think going all out on a security system may quell my fear.
its a fairly decent deterrent, people are going to get in if they are determined no matter what but at least now they cant just break a window and crawl in and crawl out and never set off the alarm.
Chuck_Finley
I picked up a cheap backup cam to use with my new receiver. Since my Tahoe didn't come with one, I assume there is just a piece of plastic where it would be between the license plate lights, I should be able to drill through that to mount, correct? Would I be better off mounting it down by the tow receiver? I'd like it for backing up and lining up my trailer but also for monitoring my boat trailer while towing. Thanks.
HiHoeSilver
Away!
Chicago
Which camera is that? Link?
PG01
Up here to the right
Not sure whats there if no camera. Better view there than lower, i use it for my trailer also.
Dont mind the salt....
Chuck_Finley
KEITHC69
