Using words like trouser might confuse young whipper snappers on here...
Trouser trout...
it's connected to the transmission not sure where but it's a bare aluminium wire (copper tin for iron blocks???)to the frame..Where would I find the transmission ground strap?
thanks, will take a lookit's connected to the transmission not sure where but it's a bare aluminium wire (copper tin for iron blocks???)to the frame..
each main part has one i.e the engine transmission etc..... that is because of seals will cause poor contact to ground
should look something like these typically...
View attachment 237885 View attachment 237886
Just going to throw this out there, a mouse got into the wiring loom that feeds the engine bay fuse box on my 2001 Yukon XL 5.3. Started throwing all sorts of transmission codes, missing gears, and could be intermittent. I went around and around trying to diagnose it and replacing stuff until I accidentally found the wiring thing mentioned way way way down in an unrelated thread on this forum. It was an easy fix, you just unbolt the top of the fuse box and lift it off to expose the wires below it. There I found a mouse nest and about 8 chewed wires. Soldered them back together and she was good as new. Not saying that's your issue but worth peeking at, maybe. That also fixed my broken outside temperature display as a bonus.thanks for replying.
The Tech thinks that a mouse has been at the wiring loom and is giving false positives but I think that is nonsense.
Fluid is pinkish and levels are correct
I bought a dell venue 10 tablet and upgraded it to windows 10 and then a vxdiag nano
the combination gives me tech2win and gds2
https://www.ebay.com/itm/Dell-Venue-10-Pro-5056-Quad-Core-1-44ghz-64Gb-Ssd-4gb-Ram-Windows-8/254221616803?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/USA-Shipping-VXDIAG-VCX-NANO-Diagnostic-Tool-V33-003-Tech2win-and-V2016-1-0-GDS2/153521246543?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
as long as it is running windows and has a available standard usb port you should be fineDoubeleive,
do you think a Microsoft Surface Pro 4 would work for this application too?
Is there something that would make the Dell a better choice?
Thanks
