Hm. That’s something to consider.2013 Denali. Slight tick at idle. Flecks in oil. If it’s the bearings on the main, labor is going to bite hard. If it’s something as simple as trunion bearings in the rocker arms, not as bad.
Here’s a scenario. If the trunion bearings are getting ready to go from low oil pressure up top, step two would be to pull the pan and verify the crank is ok.
Assuming the crank mics out for new bearings and the cylinders & rings are good you can handle the rebuild as a stage 1 upgrade .
Eliminate the AFM, skip the machining of existing heads and drop in a set of basic TrickFlow or equivalent heads. AFM will be gone, oil pressure issues resolved and you’ll have another 100k miles on a sweet 6.2L ride that’s rid of its afm Achilles heel.
I’m almost positive the pan has never been pulled, as the car was somewhat neglected from the past owners.Look under the car at the oil pan, if it has been removed for the O ring replacement you should see zero leaks around the pan, you might see socket marks on the pan bolts. At 200K there will be at least small leaks around the pan gasket.,
A pan gasket is cheap, maybe $35, O ring is less than $10. Your labor is free if you are qualified to do the pan drop. I would invest in the O ring job and see what you have.
The AFM will not engage below 26 psi I believe so it is already disabled. If it has new lifters already I would hope they replaced the AFM manifold also. That should be part of the job.
A few years ago I did a couple AFM deletes but due to smog laws I always replace all the AFM components now so it works like brand new again, along with the parts I pull the oil pan, replace the O ring and most times pull the timing cover and oil pump. If the pump is good I do increase the Oil Pressure relief spring pressure and replace the secondary oil pressure relief valve inside the oil pan.
None of the above repairs will fix bad bearings which are already failed but make a good AFM engine reliable for another 150,000 miles maybe.
You say it still runs quietly? If that is the case fix the o ring so you have oil pressure and hopefully your idle pressure jumps to over 25 hot. With the pan off replace the secondary pressure relief valve in the pan, $15, since you are in there.
Low oil pressure will allow many parts to start to fail, cam bearings are common. If the mains and rods are damaged you would have more noise or even knocking.
For about $50 you can have the oil tested and that will tell you what is in the pan and sometimes points exactly at your failure points.
You may need a new engine but with oil pressure and clean oil maybe this engine will play for a while longer
I payed a little more than a grand more than 3k for it. Which yeah for the price I took a gamble so this might be what I get.@thefrey $3k for a Yukon from a dealership is a crazy low price, even for a shady car lot. I suspect they knew about this.
At this point I would start looking and saving for a new motor and continue to drive this one until it dies
It's not where you start, it's where you finish. It's not how you go, it's how you land.So at this point it is what it is
