DjJayFrree
DJ to the Stars
East Bay Area RI
couldn't get the tabs to release... watched the video, found the tabs was unsure which way to push, didnt want to break them!
Joew311
TX
The reason you couldn't tell which way to go is because on some of them its both! I had to get a panel tool and wedge it into one side then pry slightly on the other side. It's a pain, but if you take your time you can do it. I don't remember which side I wedged the panel tool into, but if I remember correctly it's easy to see which side it should go on.
DjJayFrree
DJ to the Stars
East Bay Area RI
ya that is WAY above my pay grade
Joew311
TX
Haha, it's not as bad as it sounds...just go easy on it. I did notice that you have a Yukon, I'm assuming it's the same connection as the Tahoe/Suburban grille, but I don't know for sure.
unoigo
Detroit
Installed color matched hood molding/ trim over the weekend. Was thinking of doing whole grille, but after seeing other members photos, it just didn't look right. I think the chrome trim in the grille brings out the insert more. So went with just the hood molding instead.
Curious if anyone spots the flaw.
Before
After
raptormc
