Who else is Dropped with 28s
Migo713
Migo713
Houston
Yeah I was thinking about cutting the part where it rubs, and the angle grinder is a good idea for the bolt. I placed an order for the adustable lower control arms for the rear. Hopefully if they help I can get away without the cutting and grinding lol cause I like the way it tucks the rear tires a bit
arton28s
I have a Tahoe slammed on 28s but rear tires seem to be too close toward door side,was wondering if maybe da adjustable lower control arm will fix da problem...keep us updated if u get them install
Yeah The rear control arms worked, and they look nice!
Did you just do the lowers or both upper and lower? Are they Spohn and did you need a 4 wheel alignment after? I know that's a few questions but I've been considering it. My tires rub but only when cornering hard. Thanks!
Migo713
Migo713
Houston
I just had to use Spohn rear lower adjustable control arms. I didn't get it aligned, it drives fine to me. If I mess with the front then I will aligne it. I pushed my wheel the most back I could, to make surr
Migo713
Migo713
Houston
I had installed the one inch spacer in the rear meanwhile I fixed the rubbing. I'll take a pic soon when I take them off to get the full 6" rear drop. This is how it looks now
ccapehartusarmyINF.(ret)
Gilbert AZ
looks nice dude
those tires are painted on the rims
and LOL i dont care what kinda suspension is on it 28 inch rims with 295/25 28s is going to have one stiff ass ride
aph7649
