Baddawg
I have seen some talk about this but haven't found a good write up.
How can I add a DIC to my 2013 SSV?
Thanks.
Thanks.
Thanks.
Yes it gives u a lot more access to the computer than the old black button.
1 engine hours
2 tire pressures
3 trip mileage
Etc. It gives you all the same plus more. It will also allow you to change settings too. The cheapest upgrade you could ever get.
+I have 2014 ppv. Upgraded dash panel , ordered dic switch from dealer , found plug behind dash. Done, works .
Is the wiring harness on the right side of the steering wheel in a 2012 Tahoe PPV?They have them on Amazon. The wiring harness is already there. You can either cut out a spot with a dremel and use a hot glue gun or order the panal from chevy.
